Date: 08/01/2018 01:27 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 03/25/2019 09:02 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 10/26/2020 03:24 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
  • Online today: 600
  • Guests: 475
  • Total: 475
2.0 horsepower question
Started by 1oldtimer, June 26, 2016, 02:37:24 AM
1oldtimer
I went with the tri y header because that's what they are selling over in the UK for the 2.0l and figured it works for them. I did blend the the intake to the adapter, the motor is in a Ford Model A with a T5 and 4.11 gears. I'm looking for a good street car with some power to get around, I'm always on the lookout for a AK Miller set-up also. I drove it home on the freeway (about 75 miles) with the pinto motor in stock form and a C4 behind it (not sure of the rear end ratio). It was slower and down shifted on the hills but made it, so I figure it's going to be a lot better.
'72 2.0 in a '28 Ford.
By the way, your intake looks fine if you remove the steps below the adapter plate.  Racer Walsh said the 500 Holley 2 barrel on the stock intake made with-in 5HP of the duel 40mm dcoe set up.  Go for it!!!!
Quote from: 1oldtimer on August 06, 2016, 02:51:33 PM
Ok, the Cosworth motor is off the table.......I couldn't pay that much sight unseen (plus the pics left more questions then answers). I did get a used bigger valve head set up by Esslinger (valves, port/polish, skim), so I'll see how it looks.
On the carb side I'm thinking of a few options and would like some input. I have the stock intake that I made an adapter for a Holley 350 2bbl on it now, but which one is better......for power, streetability and somewhat mpg.
1. Holley 350 with modified stock intake
2. Short intake with 2 45 DCOE Webers
3. Custom intake with 37mm bike carbs
I'm new to the Pinto motors and some books to read. I did find 2 of David Vizzards books online (How to hot rod your 2.0 sohc ford and How to modify sohc ford engines) and a Des Hammill How to power tune your sohc Pinto and Cosworth for road and track.
Thanks for all the help.
I'm making the header now.
The intake
Tri=Y header is not the way to go on a 2.0L Pinto. The 2.0 likes RPM and more RPM. 4 into one is the only way to go. Been there / tried that since 1973.
L.D
I had a 2.0 I built in the early 80,s with an esslinger head fully ported big valves and shaved down around 100 thousand with flat top trw pistons and total seal rings with zero deck clearance top of piston level with top of block and a crane cam headers the hole nine yards esslinger estimated around 180 hp depending on intake. I had a Weiland 4 barrel intake with a holley 390 also had the esslingers 4 mukinis . My buddy had a 2.0 with the AK Miller set up draw thru with a 45 weber and head work mild cam good rods and forged pistons pulled alot harder and was more streetable. But since you have the head that's been shaved go with dual 45 webers.
I am anticipating 160 - 170 hp with my new 2.0 engine . Lots of head work done, big valves big cam etc.
robertwwithee
I guess it was possible but I personally didn't have access to make brackets work at that time of my life.
It makes me wonder if the later Euro 8v heads are better than the '71-73 parts we got. A quick browse on select forums and youtube reveals numerous claims of power levels in the 200hp range and approaching 250 for very serious, yet supposedly reliable 9000rpm+ race setups.
Quote from: robertwwithee on August 18, 2016, 09:37:36 PM
I did the bike carbs when I was 25 and every day lifting the hood to choke them individually stunk
Choke cable?
robertwwithee
Quote from: dick1172762 on June 27, 2016, 10:44:54 AM
The only way you can make over 150 hp is by moving the intake ports ($$$$) upward on the head. Lot of work and money. Racer Walsh once told me that he had only seen 5 motors that made over 175 hp on the dyno.  2.3L is not the greatest but much better than a 2.0L.
I've always thought that too. the stock ones are too close to horizontal and straighter shot at the valve head was looking real attractive.  nearly did it back in 1972 but life got in the way.
1oldtimer
The intake
Quote from: 1oldtimer on June 26, 2016, 11:53:24 PM
I was wondering if a 2.0 re worked head will compare to a stock cosworth dohc head.
In my opinion, an 8v iron head absolutely will not compare to an aluminum 16v Cosworth YB head. 170bhp out of a 16v 2.0L is "only" 85hp/L and ought to be pretty doable on pump gas compression ratios, especially if the cams are bigger and the power happens at a higher RPM.
QuoteI'm thinking that with 2 cams I could make more power with less strain on the motor or at least the valvetrain, but is it enough to make the extra expense worth it.
Well, that's a question only you can answer. So far you haven't elaborated on what you want out of the overall package. Is it a street car or track car?
I would be more inclined to use a turbocharger on an iron-headed 2.0 to get to 200hp than to try twisting to get there. After all, RPM Ruins Peoples' Motors.  ;)
If you want power out of the 2.0  EFI + turbo is the only real way to go. After all the this no replacement for displacement except for boost !
1oldtimer
Thanks for the input guys.
I'm trying to decide to either build the 2.0 up or save my money and get some cosworth parts for it. I was wondering if a 2.0 re worked head will compare to a stock cosworth dohc head. I found a cosworth that was build by a race engine builder, that claimed 170hp from a stock 2.0 pinto lower end, ported cosworth head and stock cams. I was thinking you could get it to maybe 180-185 with some cams.
72pair
I agree with above. 130 to 150hp is reasonable normally aspirated. This will still take headwork, bigger cam and hardware, header, more carb, etc. There are a lot of dirt racers in my area and 200hp is expensive to come by even with the 2.3 and a much better aftermarket parts supply. They're turning upwards of 8000 rpm to do so. 130hp would still be a 30++% increase over a stock 2.0. My $.02.
72Wagon
Anything naturally aspirated above 150 hp gets expensive and drivability goes down in my opinion.
1972 Wagon
1oldtimer
How much horse power could you reasonably make with a carb'd motor. I'm taking about safe, reliable, something that won't eat away at cam bearings....something with possibly bigger valves, head work, decent cam, header, holley 2bbl carb and slightly higher compression.
I'm looking for a ball park. Is 180-200 out of the question, I know about torque vs hp but just wanted to compare.
