Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 05/24/2020 08:19 am
Date: 04/13/2018 11:30 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Wanted early pinto
  • Online today: 1,166
  • Guests: 1069
  • Total: 1069
1976 pinto rear disc problem
Started by pegasus2050, June 02, 2016, 07:17:16 PM
and don't forget to bench bleed the master cylinder before putting it on the car. that is a big known issue with your symptoms.
82expghost
Take pics of any modifications
Sent from my E6782 using Tapatalk
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
pegasus2050
found some information on cme web site last night I have decided to install a brake master cylinder for a 1979 corvette which came with four wheel disc brakes. found out that this type master cylinder has different type valves inside than a disc/drum brake master cylinder. going to change master cylinder Saturday will let you know how it works out.
How about the proportioning valve???.
82expghost
I bet because of the disk brakes, the pistons in them are bigger than a wheel cylinder, so means it needs more fluid movement, so you may need a bigger bore master, or you still have air in the lines
pegasus2050
recently installed rear disc brake on my pro street pinto. disc brake setup consists of 1982 chevy calipers and after market mounting brackets. problem I am having is that I can't get a good firm brake pedal. if you pump the brake pedal you get a firm pedal otherwise the pedal will go to the floor.when I had the drum brakes on the car I always had a good firm pedal. by the way this is not a power brake setup. any suggestions. have changed the brake master cylinder and bled the entire brake system and still have the same results. front brakes is the same setup 1982 chevy calipers and 9 inch rotors.
