Date: 09/10/2018 10:41 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 02/28/2018 09:33 am
Oddsnends
Date: 12/20/2016 10:52 am
SVO SWAP
Date: 03/15/2018 03:12 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
71-73 sway bar
Date: 06/12/2021 10:12 am
1972 pinto grill
Date: 02/27/2018 12:13 am
  • Online today: 2,399
  • Guests: 1573
  • Total: 1573
77 pinto turbo project
Started by 82expghost, June 02, 2016, 01:40:58 AM
Francis Stanisci
Question. I've thought about moving the turbo from the 79 Fox Body to the 77 CW, but the wiring looks like a total nightmare. I was wondering does everything need to be reused or can stuff be eliminated. We're NOT smog governed here, not yet anyway. So if stuff can be bypassed/eliminated that would be so awesome. Any helpful links would be greatly appreciated.
Love the bay on yours. That's awesome. Selling one of my rides to help fund the many projects I have (1967 XR7, 77 CW, 79 Fox Body). Really want to get back into this stuff.
bbobcat75
nice build and write up!!!! POST MORE PICS!!
1975 mercury bobcat 2.8 auto
82expghost
This is a pic of the factory fuel sending unit that has 3/8 stainless fuel line with a 5/16 return line tigged in, finished off with an line going to the Walbro 255
Sent from my E6782 using Tapatalk
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
82expghost
These are the pics with the new heart in and fabbing up the charge pipe going to the front mount intercooler and the wastegate dump pipe that I have vented down to the atmosphere,...... sounds great
The turbo manifold is a cheap center mount xs manifold with a two bolt 34mm wastegate hole
Turbo is the stock merkur turbo with the internal wastegate hole welded closed
Wastegate is a emusa 34mm wastegate with a 10lb spring and controlled by a greddy style boost controller
82expghost
Cleaned and painted the t9 trans, got a 12lb custom made flywheel and custom made Kevlar mixed kinda 2.5 stage clutch with reworked pressure plate
Had to cut and remake the transmission member to make room for the 3" exhaust, and in the pics you can see the Volvo motor mount that screws into the bottom of the trans, and one hole drilled in the middle of the transmission member to bolt the other end of the mount too
Remember when using the t9, might want to cut the shifter and rotate so that it isn't aimed towards the passenger seat
82expghost
Thanks 74 pinto wagon, the car is finished now, I just started posting the pictures I have takin along the way
82expghost
Old heart out, clean and painted the engine bay, removed head light harness for modification to run it outside the engine bay
82expghost
The making of the lowered intake to clear the hood, and the turbo joe fuel rail added to the motor
82expghost
Setting correct pinion angle
82expghost
First stage, upgrade where the power is going to be going, landrum springs on all four corners, and pro stock shocks, drop spindles, and 8.8 limited slip with 2.72 gear out of Fox body, to keep bolt pattern
