71-73 Hood
Date: 12/07/2018 06:22 pm
door sills
Date: 03/14/2020 03:20 pm
Date: 08/02/2019 04:18 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 10/05/2017 02:26 pm
Date: 08/16/2018 08:54 am
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
  • Online today: 548
  • Guests: 325
  • Total: 325
77 pinto stock tachometer
Started by Vicrydr, June 01, 2016, 01:50:17 PM
Vicrydr
5.0 Chero
Just hook you tach signal wire to the TFI coil if I remember correctly the wire color should be green possibly with a red stripe
Vicrydr
As the in dash stock tachometer is not cable driven and works by wire connected to coil the way it looks. In changing over to an  EFI engine and wiring harness from the 86 Ranger, I have taken out the old coil and box for spark control. I am now wondering how to wire the tach so it will work again. Maybe tapping into plus side of the newer style coil I have mounted in from the 86 Ranger? Haven't really seen anything on the forums yet.
