Date: 04/25/2017 12:17 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 02/18/2017 04:47 pm
Date: 03/07/2017 07:03 pm
Date: 04/10/2017 07:30 pm
Date: 06/30/2018 09:48 am
Date: 02/08/2018 02:26 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
  • Online today: 1,166
  • Guests: 1110
  • Total: 1110
Wheel removal
Started by arkyt, May 02, 2016, 07:32:04 PM
I sit on the ground, facing the wheel and kick my legs outward at the edge of the tire. You could also try rolling a loose wheel/tire into the same area (but watch that you don't hit the body). Basically you need a strong force and the leverage there of (why you hit the outer edge of the tire) to jolt the wheel loose. Do this at your own risk.
My wife had a Dodge Intrepid and every 5K miles that I rotated the tires I had to"kick" them loose. The steel and aluminum seems to super glue themselves together quite well.
arkyt
Pulled an old one out of the weeds that had been sitting for years with non-stock aluminum wheels.  Lug nuts easy.  Can't get the rear wheel off!  May have a spacer in there.  Soaking everything that I could spray right now.  Any suggestions?  Don't want to hurt the wheels.
78 sedan
77 V8 cruizin wagon
73 MGB
09 Challenger RT
