A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 02/18/2017 04:41 pm
Date: 03/06/2017 01:19 am
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 01/12/2019 10:19 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 07/20/2018 03:00 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
  • Online today: 1,166
  • Guests: 1083
  • Total: 1083
72 Runabout can I install motor/trans as one?
Started by 442, May 02, 2016, 10:22:37 AM
442
Thanks, that solution borders on brilliant!  Richard (non Vega owner) haha
I do it all the time with a 2.3 / fog, which is bigger than a 1600. Leave the front end stock without any jacking up at all. Then jack up the rear end as far as you can. You will now have the car on an angle and the engine/tranie will slip right in. Set your creeper under the car so the tranie tail shaft can rest on it as the engine/tranie goes in and down. Then lower the rear end of the car as you jack up the tranie tail shaft. Easy enough that a Vega owner could do it.
442
Hi,    I have a 72' Runabout with the 1.6 and FOG transmission.  I bought it with the trans already removed, I have since pulled the motor and would like to install both together if possible.  Looks too tight though.  Is this doable?  Thanks for any info.
