Date: 01/23/2017 07:41 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
77-78 front grill
Date: 04/07/2017 12:35 am
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Built 2.0
Date: 10/07/2018 05:27 pm
Date: 07/20/2017 01:23 am
Date: 05/21/2019 11:50 am
nos core support
Date: 01/03/2020 09:39 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 600
  • Guests: 351
  • Total: 351
charging system help
Started by robw, August 09, 2005, 09:57:35 AM
I had the same problem on one of my Mustangs.  With the regulator plugged in the battery terminals would arc pretty good when connecting the battery.  It ended up being the regulator.  I would take the alternator off and have it checked regardless.  Good luck :)
TonyB
Sounds like a diode problem.   Checker/Kragen/Schucks http://www.cskauto.com/stock individual alternator parts (brushes, diodes, bearings, etc) from $8 to $15 ea, as well as a generic regulator for $15.   Should be cheap enough to swap parts & troubleshoot.
HTH
Tony
'72 Pinto Runabout, 2.0, Big Valve head, T-5, 8" w/ 3.73 Posi.   Currently awaiting $$$ & Time
robw
i have a 1980 pinto 2.3/auto and am having trouble with the charging system. the problem is if I leave the regulator plugged in it will drain the battery over night. do you think it is the regulator or the alternator, i know ford alternators have diodes in the and if one goes it will feed back and drain the battery.thank you
