$300 Pinto for sale
Date: 04/19/2017 10:24 am
convert to stick
Date: 05/19/2018 09:26 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 12/09/2016 08:34 am
Date: 10/04/2019 08:43 pm
Date: 03/13/2021 12:57 pm
Date: 05/13/2021 05:33 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
  • Online today: 489
  • Guests: 187
  • Total: 187
79 rear bumper question
Started by shuffln, March 13, 2016, 08:23:19 PM
76hotrodpinto
If you're talking about just bolt on swap, I have no idea. If you're handy with the metallurgical arts, you can chop and section just about anything to fit.
shuffln
Perfect  now I know why it's sitting low. What bumpers other then pinto will fit
76hotrodpinto
shuffln
So now that I took the bumper mounts off a few weeks ago I completely forgot where the leaf spring shackle mounts, last set of holes or the middle two . I'm thinking middle 2 or second set in especially if we cut the first 2 off and move the isolator in
chrisf1219
hi on my 77 wagon drilled out isolater to find out it was solid like clear gasket sealer.had to cut of end of it and  pry out solid goop then press it together in a vise.weld it or if no welder I drilled and put a large bolt though it.i was able to bring bumber in apox 3 plus inches. good luck chris
76hotrodpinto
Mines a 76... well that area is, but here's what I did. I removed the rear shackle mounts, bumper and skirt. Then moved the holes on the bumper mounting plate forward so that the first hole on plate is lined up with last hole on frame. On mine, that position worked, so I drilled out the plate to match the other 4 frame holes, in that position. Cut off the excess plate, where the no longer used hole are, then re-assembled it. On mine, the skirt was stapled on, so I had to tack up some holes and grind it out a little. And if none of the factory holes line up well for yours, you may have to plot all 6 holes, I recommend using a template.
Ps.
I don't have a factory fuel tank, so that might have made it easier.
robertwwithee
Only on a vw rabbit.  Haven't done on pinto.
shuffln
So I've tucked my front bumper now for the back, I've heard that you can drill out the isolator and push the piston in your move the bumper closer. Has anyone done this or has tucked there rear 79-80 bumper let me know.
