V8 rear end
Date: 04/12/2018 10:57 am
Date: 08/27/2018 11:11 am
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 07/13/2018 02:21 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
convert to stick
Date: 05/19/2018 09:26 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
  • Online today: 1,166
  • Guests: 139
  • Total: 139
1974 pinto coupe weird starting issues
Started by Jon Britton, March 12, 2016, 07:22:19 PM
Jon Britton
Ok bought a new fusible link for the relay. Old one was definitely fried, haven't installed it yet. Bought a new key cylinder instead of adjusting old one. And looking at fuse block I found severe corrosion etc. So I'm replacing it with an updated blade fuse block. Will post more as it comes along.
I just checked, there is an adjustment that can be made on the actuator rod that goes from the key switch to the ignition switch. That could be needed to be done. I tried to print and the scan the instructions, but I have no clue where this thing put the scans.
Jon Britton
It's very possible, he had that thing redneck special. Which as soon as this thing gets running will be more undoing of his rigging on various other areas of the car lol.
Jon Britton
I'll definitely check this out asap tomorrow, and yeah the s lug wire is 16ga with voltage both with wire and without. Both times key in at start or out of switch didn't matter. Thanks for the info on the manual too. Hope things look better for you soon. I'll be posting soon of my findings.
I can't make out on the diagram you posted what that wire is going to, more because of my bad eyes than anything else. Have no clue what or where my diagram got to. I've pretty much rewired my own way the car I have, so the diagram at this point is useless for my car.
But remember, if it is blown it did it for a reason. So don't replace it with regular wire, and try to figure out why it blew first. Probably one of the hacks the PO did caused it though.
Quote from: Jon Britton on April 04, 2016, 10:08:12 PM
I think I may see a problem, the yellow wire that powers the ignition switch has a fusible link right where it connects to battery side of starter relay. It looks blown, could this possibly be a factor?
It certainly won't help things. You can do a continuity check on it to verify if it is bad. If you have nice pointy probes on your meter, or just trace it out to a start and end point. That could be why the PO had the push start and stuff on it. But try to find it on your diagram and see what circuit it is supposed to protect. Might be for something else?
This would be so much easier in person. I know it must be frustrating for you to try to follow all my crazy instructions.
Ok, that is not good. The S lug (small one next to the I, 16 or so gauge wire, correct?) should only have voltage with both the wire connected AND the key in the Start position. Is the voltage on it without the wired being connected there, or only with the wire connected, or both? If it is there without being connected then the solenoid is bad somehow. Internal short most likely. If only when the wire is connected there is a wiring problem somewhere in that circuit. This also could be the key switch being bad, where it still makes contact to the Start circuit. In fact that is where I would recommend you try next. Try to trace out the wiring with that diagram and see if the S position on the key switch is on all the time. You should be able to check it at the ignition switch you just changed out. Use your old one to find the wire locations, might help make it easier. ??? At least it is not under the dash.
Do you still have the old solenoid? If so, do those tests with it installed and see if you get the same results.
"So checked the starter side of relay, I get 12v with key in start. I also get 12v with key not in ignition at all." and also "With the starter cable disconnected the starter cable lug has no volts with key in start and off." This last is strange. You should have the 12VDC on the starter side of the relay regardless of if the starter cable is connected or not.
Maybe like I said above it is the keyed switch in the column. that would explain most all of this stuff. I thought there was an adjustment on these, but I am not seeing it in the manual.
But then this is not being my best week.
Do you have the factory service manual for this car? Here is one place to get it if you don't. A Haynes or Chilton's won't really cut it.
http://www.ebay.com/itm/1974-Ford-Lincoln-Mercury-Shop-Service-Repair-Manual-CD-OEM-Mechanic-Guide-/130741225454?fits=Year%3A1974|Make%3AFord|Model%3APinto&hash=item1e70c8c7ee:g:Yz4AAOSwB4NWvA MD&vxp=mtr
Jon Britton
Jon Britton
S lug has volts however, both key in start and key off.
Jon Britton
With the starter cable disconnected the starter cable lug has no volts with key in start and off. With the I wire disconnected, it still has zero volts in both positions and with S wire disconnected it does as well.
Ground is clean and has a braided ground from block to chasis.
The only thing that sticks out to me is that with no starter cable connected there is no voltage on the lug for reason. Hooked up and the voltage comes back with key in start and with key not in cylinder.
I think you may have misunderstood me, which is common. Just ask my wife.  ;D
I meant to remove those wires, and check the starter cable post with the key on and off.
So let me try it this way.
1. Disconnect starter cable from solenoid. All other wires still connected.
Does the starter cable lug have 12VDC with the key on? Should be 12VDC.
Does the starter cable lug have 12VDC with the key off? Should be 0VDC.
2. With the starter cable still off, remove all the wires from the I connector.
Does the starter cable lug have 12VDC with the key on? Should be 0VDC.
3. With the starter cable and the I connector wires still off, remove the wire from the S connector.
4. With everything above still disconnected,
Does the I lug have 12VDC with the key on? Should be 0VDC.
Does the I lug have 12VDC with the key off? Should be 0VDC.
5. With everything above still disconnected,
Does the S lug have 12VDC with the key on? Should be 0VDC.
Does the S lug have 12VDC with the key off? Should be 0VDC.
Let me know what the results are. Should only take a few minutes, took longer to type than it will to test.
Oh, you probably already did this, but make sure the mounting bracket (part of the solenoid) has a good clean connection to the body. That is the ground for all of this, and if it doesn't have a good ground all sorts of weird things can happen. And you said this was an engine swap, so make sure that there is at least one ground cable (braided or whatever) going from the engine block to the body/subframe. I run another starter type battery cable from the point on the block where the battery negative goes to somewhere on the subframe, wherever there is a convenient hold for a nut/bolt. But one of those braided wire ground cables is fine. I just like overkill.  8)
Jon Britton
Without the starter wire the I post also gets no volts. However the s post gets 12 v.
Jon Britton
Sorry to hear about the job, we'll disconnected the starter and don't have any volts.
Well, I will be online more than I had thought from now on. Lost the job. Oh, well.
Maybe we can get this car fixed sooner.
Jon Britton
Ok, I'll continue on it tomorrow and post the findings for when you're able to get back on.
I was more concerned if you had one or not. Hard to do with one, almost impossible without.
If you disconnect the starter cable, do you still have 12V on that connector on the solenoid all the time, or only when you have the key in the ON position? Same question but with first the S wire removed, and then with the I wires removed? And then with both S and I removed? I'm trying to find a way to narrow down where you have to look for problems in the harness.
You said the thing was a bit hacked up. Are you sure all the hacks are undone? I am not familiar enough with the seatbelt interlock, as I just totally removed that from mine. I wouldn't think that bypassing it could cause what you are seeing. But???
And fyi, I probably won't be online after tonight until Friday. So if I don't respond don't think I have abandoned you.
Jon Britton
I may have to email it if you want. It's a pdf file so I had to screen shot it. Kinda fuzzy though
Jon Britton
Jon Britton
Ok, so it won't let me post images now. Anyone now how, maybe I missed something. On an Android phone.
Jon Britton
I have one someone off here gave me, but it doesn't include the interlock system. I'll see if I can post it
OK, darn it. That would have been too simple.
As far as the test you did with the meter, did you check the meter by touching the two leads together and the reading went to zero more or less? If so, then the solenoid is good from that stand point.
So we are back to there being something wrong with the wiring harness. Could possibly be the starter, but not likely given your symptoms.
Do you have the wiring diagrams for this?  I do have a laminated wiring diagram I got off of Ebay, but don't know where it is at the moment. I'll try to find it.
Jon Britton
Yeah that's my handy work. No the cable is blocking the view, two separate wires, both going into the harness that is just behind the relay.
The wiring looks good, did you do that?
Anyway, I see a possible issue if I am seeing it right. It looks like the blue wire from the S terminal is looped to the I terminal. Am I seeing it right? The one cable is blocking part of the view so I am not positive.
Jon Britton
O, and the other small wire right side, goes to the ignition coil.
Jon Britton
. The starter is the old ford style no solenoid. I disconnected all the wires and cables and checked it on ohms and well, got nothing, meter never changed. I even checked the meter to be sure. So if I'm understanding correctly, does this mean the relay is bad? As far a wiring goes, the starter is wired to the right side post, positive battery is wired to other post which is closest to it. Start wire is on left front small post and run and accessories wire is on right small post. Yellow continuous power wire is also on left side big post with positive battery cable. I did notice though that the yellow wire connection looks like a melted fusible link rubber end.
Follow up question since I don't know this.
You said the engine is from an 84 Ranger. What style starter does it have? What I mean is does it look like the old Ford style, or a Chevy with a solenoid attached to the starter itself?
The reason I am asking is the two types are wired completely different. The original Pinto starter ( and hence all the wiring) is for the old Ford style.
I think the 84 should still be the original style, but it could have been changed by a PO (previous owner).
hmmm. That last thing you posted is saying there is A) something causing the solenoid to be turned on all the time, or B) the solenoid itself is shorted.
You said you replaced it already, correct? Doesn't mean the new one isn't bad though.
Disconnect all the wires and cables from it, remembering to mark them or take a picture so you know where they go back. Using the ohms function of the meter measure from the battery post side of the solenoid to the starter side. Should be an open, infinite resistance. If it is then the solenoid itself isn't shorted. If you get something in the mega ohms range, same thing. If it reads a few or less ohms there is a short (it is stuck in the on position or an internal short). Whatever it reads let us know. If you don't know how to do this just ask.
Not knowing what you know about this stuff, here is some info.
The solenoid is just a relay.There are two types. Normally open and Normally closed. That means when no power is applied a normally open relay is open, and the normally closed is closed. When power is applied the normally open becomes closed (completing the circuit) and the normally closed becomes open (the circuit no longer will conduct). The hot (battery) side is normally not connected to the starter side. But when you put the key in the start  position, the wire going to the little connector causes the relay to be turned on, causing the hot and starter sides to be connected.
Would it be possible for you to take and post a picture of the relay/solenoid showing the wiring, including the cables? That would be a big help to make sure it isn't something simple like a wire in the wrong place.
Again, I am assuming you know nothing about this stuff.
Jon Britton
Jon Britton
I'm glad you like electrical lol. I do have aa dvm and a test light, will have to check that next. What I do know about the car is:
Not the original engine, this one comes from an 84 ranger 2.3
Wiring is original however, even the seatbelt interlock sytem.
As well as the rest of the car including the front tires lol.
Someone had attempted to install equis gauges, badly I might add.
And they had also rig some sort of push and toggle system to start the car. All of this was one giant rats nest of wires and naked splices.
The interlock system has both relays still but has been bypassed at the reset switch. The ignition switch is new, but the key cylinder is not.
Buzzer works, dome light works and now all exterior lights work. You can jump the starter relay and it will start but I fried the last one I did that too. And I have run a wire from the starter relay to a button with the constant power (yellow) wire, and it would start just wouldn't turn off.
So far that's all I know....
Well, I l like doing electrical. But I am weird.
I'm an electronic tech by trade. Car electrical is close enough. Most of what I used to work on has 12VDC as a power source.
Do you happen to have a DVM (digital volt meter) or at least a decent 12V test light? If so, check the connection at the starter relay that goes to the starter when you have the key turned to start. If you have 12V ( or the light lights) then you have an open in between there and the starter, or even a bad starter. Or possibly not enought current even though there is the 12V there.  If no 12V there, remove the starter cable from there and try again. If you now have 12V (or the light lights up) there is most likely a short in the starter or the cable going to it. If no 12V with the starter cable disconnected, then the problem is in the starter relay or the wiring going to it. That could be all the way back to the ignition switch.
There is a fuseable link in the ignition circuit. That is a wire of a smaller gauge that is intended to burn up to prevent a fire in the case of an extreme short. I don't remember if it is part of the starter circuit or not. But something else to look into. If it has burned, the insulation will be bubbled. These are a short (4 or 6 inch) piece that is in the wiring. There are a few, for different circuits. This is more of an fyi in case you haven't come across that stuff before.
Is this car pretty much stock, like factory alternator, gauges, etc? If not, that could be another avenue to pursue. I wasn't thinking non stock from your first post, but there are things that can be done wrong that makes the car run after the ignition switch is turned off from a feedback thru the alternator. If it is stock ignore all this.
