Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 10/02/2017 02:16 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 07/04/2017 03:26 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 02/03/2018 11:28 am
  • Online today: 1,166
  • Guests: 159
  • Total: 159
Water Pump Removal 1977 Pinto
Started by hoosierboyinga, March 05, 2016, 06:23:18 PM
82expghost
you dont need to remove the timing components, just remove the pully and fan with a wrench and the loosen the belts and the pully wheel will fall off, then two hoses and three bolts, jusyt removed mine to weld an bungs on it
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
76hotrodpinto
That's what we try to do here. Glad to hear it went well for you.
hoosierboyinga
Thanks great information and it worked perfectly!
76hotrodpinto
It has 4 small bolts. Just remove them, and maybe tap it a little, and it will fall off.
hoosierboyinga
Do I have to use a pulley puller?
76hotrodpinto
You'll have to pull everything down to the timing belt, to clear your way to the pump. Drain your coolant, and pull the hoses from the pump. Remove the pump mounting bolts, 3 I think, and viola! Clean up the mating surface and do it all backwards.
hoosierboyinga
76hotrodpinto
Which motor does it have? Either motor, you should be able to get the pulley off with a regular socket set, or wrenches.
hoosierboyinga
How hard is it to remove a water pump in a 1977 Pinto? What do I need to remove pulley?
