Date: 01/04/2017 04:07 am
Date: 09/10/2018 10:41 pm
Date: 09/21/2018 11:35 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 06/07/2018 01:45 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 02/18/2017 05:52 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 02/08/2018 02:26 pm
  • Online today: 1,166
  • Guests: 182
  • Total: 182
needing clutch/brake set up
Started by 78_starsky, February 14, 2016, 04:20:15 PM
5.0 Chero
Have to back out parts no longer there
5.0 Chero
Well it dose not look to economical for me to pull it and ship it to you . The yard wants $125 for the pedal assembly and the cable,with my time to pull it you will be looking at about $175 plus shipping priority flat rate large box is $60 to Canada...
railmania
here is the plate I have.  It is for mounting a brake booster.  The one I need has a smaller hole for the brake master cylinder to attach.
I could also use the brake lines from the master brake cylinder.
Thanks
Quote from: 78_starsky on February 14, 2016, 04:20:15 PM
Looking for anyone who is wrecking a pinto/bobcat/mustang2 that is standard.  Friend is needing the brake/clutch pedals and the cable assembly.
using it for a T5 set up in a 76 Pinto.
Thanks all.
Cheers
The pedals from 74 and earlier are different.  75 and up are the ones you are looking for.  The bracket or hanger should be the same,  the holes should already be present on the side already to mount the clutch pedal.  The only other thing is if the car has power brakes or not as the brake pedal will be different.  Good luck in your search.
5.0 Chero
Go ahead Robert and quote him a  price as I just know there was one a yard I deal with
robertwwithee
I have 73 manual that I'm parting. Out as well.
5.0 Chero
railmania
I would be very interested in the firewall mounting plate. I need the plate for a non booster/non power brake. It should be two bolts after removing the pedal assembly.
Thanks, Kevin
5.0 Chero
I will check part is still there and get a price to you this week end
78_starsky
Hi,  He said that he needs the hangers also.  Angie said probably easier to ship to her pick-up account that is in the states. I always forget about it. So shipping will remain in the US for you. Unless it is just as easy to ship here.
thanks
5.0 Chero
The hanger s what the pedals mount to as of right now I have nothing but I know where one was in a local yard I can check. Shipping to Canada is possible
78_starsky
Hi,  not sure what that means,  i will ask him tomorrow night and get back to you. What parts do you have for sale and are you willing to ship to Canada?
thanks
5.0 Chero
78_starsky
Thanks all.
Cheers
