2.3 pinto carb
Date: 08/18/2018 02:07 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 02/28/2018 09:33 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 12/31/2017 09:03 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 1,166
  • Guests: 140
  • Total: 140
Steel fuel line size?
Started by Glitch666, February 14, 2016, 12:51:56 AM
Glitch666
Ok cool, ill probably do the flexible an style hose with a 37 degree flare. The original lines where screwed when the motor was pulled for me, not a big deal as he through in the 86 svo harness and pe ecu.
76hotrodpinto
I think there were 2x5/16 lines and a 1/4 line for the evap system. I'm not sure I would go with solid lines to the fuel rail. At least with mine, the engine vibration and torquing would certainly cause metal fatigue and leaking. I used the fuel rail connectors that came with the tbird donor, put new rubber on them and put them in. I would highly recommend leaving some flexibility between the hard lines and the fuel rail.
Glitch666
I wasn't really planning on replacing any, just extending to get it up to the fuel rail. So yours was 5/16th for supply and return?
76hotrodpinto
I got 5/16 on my 76. Didn't have to replace any though. I just flushed them out and pressure tested them to 70lbs. I just put the flexible lines up to the fuel rail and the same out back with the pump. I run a fuel cell with fats, not a tank.
Glitch666
I was thinking of doing a double flare coupler with more steel line up to the fuel rail, or doing a AN style with tube sleeve and 37 degree flare with some braided high pressure lines up to the AN sae quick disconnects.
5.0 Chero
Are you going to plumb it with steel line or High pressure EFI line ad factory style fittings?
Glitch666
Hi guys, im in the process of swapping a 2.3 turbo into my 76, all the works being done at my dads and im at home and was planning on ordering a few things for the swap. Does anybody know what size the steel fuel and return lines that run to the tank are? Im pretty sure they are 5/16th? but i just want to make sure before I place the order.
