Date: 02/18/2017 04:44 pm
Date: 09/10/2018 10:41 pm
Date: 02/18/2017 05:55 pm
looking for parts
Date: 06/19/2020 02:32 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 02/05/2020 11:06 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 1,166
  • Guests: 170
  • Total: 170
cam swap
Started by krazi, December 30, 2015, 09:03:35 PM
fordblue72
Which isky stick are you using, I am looking at a 465 for my 72 with a 2.0 and a 4 speed.
krazi
oil in the muffler. when it warms up again, im going to pull the heads and try to find out what I did wrong.
yeah, I'm Krazi!
Yeah, if you have oil ON the muffler it is an external leak. Could be something as simple as a valve cover gasket. Worst case cracked block, but very unlikely unless you are running nitrous or pushing several hundred horses.
Clean the engine and monitor for a leak.
Sounds like you have a leak somewhere and oil is dripping on the exhaust, that's why you're seeing smoke????..
krazi
I installed an isky race cam last summer. dropped the engine and trans in and hooked everything up, and it started on the first try. drove it for a few weeks, took it out on the highway to open it up, and noticed a trail of smoke following me at around 2500 rpm. got home with it, and noticed oil dripping off the glass-packs. did I miss something? I know I torqued the heads properly, and pretty sure I cleaned the block and heads. maybe a ring failed. maybe the valve guides failed. maybe I should have used different valve springs. any advice would be greatly appreciated.
krazi
yeah, I'm Krazi!
