Date: 02/18/2017 05:52 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 02/28/2018 09:37 am
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Front sump oil pan
Date: 01/02/2017 06:54 pm
  • Online today: 1,166
  • Guests: 137
  • Total: 137
New brake proportioning valve?
Started by pintoguy76, December 14, 2015, 09:21:37 AM
Ok. Any recommendations on which one to get? Wilwood has one that looks pretty nice and comes with a bracket to mount it right beside or below the master cylinder...
Real easy to adjust and they are fairly close when you get one, try it as you get it and if the back locks up too easy then reduce the pressure and vice versa, adjust until you get the braking you're comfortable with.
Yep. I tried to bench bleed it 2 or 3 times... Aftermarket would be fine with me.... but I'm worried about getting it set properly....aftermarket would most likely have to be adustable... because one setting wouldnt work for all cars....
Did you bench bleed the master cylinder before installing it?
Are you wanting to stick with a stock valve, or would you be willing to use an aftermarket one? Not sure of any stock ones new, but all sorts of aftermarket ones, but you would likely need to re-plumb a bit.
I cant seem to get the brakes right on my pinto (74 Wagon). Ive replaced the master cylinder and the wheel cylinders and the front and rear hoses, and bled and bled and bled and bled the system and I simply cant get the brakes right. It always requires one pump before the pedal is full and firm. Ive read the proportioning valve could be the problem, and it is not available new that I can find. I was wondering if maybe I could use a fox mustang valve or something from a similar sized car with front disc and rear drum brakes. Am also thinking about a NEW (not reman) Ranger master cylinder... (Maybe a ranger proportioning valve will work?) A pinto MC isnt available new, and i kinda feel like a 40 year old master cylinder probably wont work right even after its been rebuilt... so I want a new modern style MC from a ranger and some kind of NEW proportioning valve.
Any ideas ??
