Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Date: 12/10/2017 01:14 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
80 pinto original
Date: 08/04/2019 10:45 am
Looking for front seats
Date: 08/10/2021 09:54 pm
V8 rear end
Date: 04/12/2018 10:57 am
78 windshield trim
Date: 02/01/2020 08:46 am
Date: 06/25/2021 12:59 am
looking for parts
Date: 06/19/2020 02:32 pm
  • Online today: 642
  • Guests: 175
  • Total: 175
T5 Swap Trans Mount
Started by dardave, November 17, 2015, 09:51:38 AM
A word of caution: With a 71-73 and a 2.3 swap the room is very limited for the forward movement - and I tried to get everything back as far as I could go.
Mine is the old C4 mount from my 79 F150 with a rectangular box made from steel. No bolt hole slotting & works great.
yhalkeeiron
Sent from my SM-G900P using Tapatalk
yhalkeeiron
yhalkeeiron
I used a 1990 Mustang 2.3 trans mount. Basically if you don't care if your engine is father forward there is no modifications necessary just push the whole trans and engine forward. You will need to loosen the nuts on the motor mounts. But I don't recommend that I would get a drill and drill 2 holes in your  trans mount. In my car I pushed the bell housing all the way to the fire will trying to get as much weight to the back of the car as possible. Hey Paul I didn't help too much but it's the thought that counts
It's going to depend on which transmission mount you use.
My '72 originally had a single-bolt mount. When I put an '86 Thunderbird 2.3T/T5 in it, all I had to do was elongate the stock crossmember bolt hole without reversing the crossmember.
Dave,
  Here are the pictures.  Not too much, but all I have.  As I said before, I'm not sure if I had to enlarge the holes that bolt to the transmission or not. I know when I did the swap I had the mentality that if I slotted all the bolt holes it would allow for placement flexibility.  The crossmember is reversed and slotted (all the way back).  I've also included a picture of the bracket to offset the clutch cable that elevates it over the crossmember. Most have found this necessary. Update: I included a picture of the installation.
  Some had recommended Dave use the Turbo Coupe mount. I could not find a way to make it work (seemed too big). If any of you have I'm sure he (and I ) would appreciate what you did.
dardave
I am in the process of doing a T5 trans swap in my 72' 2.0 car. I need help with the rear trans mount. Some out there are saying they used a C4 bracket to bolt to the trans and the C4 mount. Using the stock crossmember turned around and elongating the holes. Does anyone have pictures of the parts used? Thanks! - Dave
