Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 07/20/2018 03:00 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 03/07/2017 07:03 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 08/09/2018 07:49 am
77-78 front grill
Date: 04/07/2017 12:35 am
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
  • Online today: 330
  • Guests: 319
  • Total: 319
1974 rear axle
Started by azz101462, November 14, 2015, 03:21:15 PM
Give these guys a call. They built the 8 inch for my road race car. They can answer any questions on rear ends and build you a rear end to match your needs.
http://currieenterprises2.reachlocal.net/?utm_source=Reachlocal&utm_medium=ReachlocalPPC&utm_campaign=4kRearEndCampaign
entropy
Quote from: 71HANTO on November 17, 2015, 09:40:27 PM
Here is a link that discusses the Versailles rear end for the early Mustang guys that you may find interesting. You MAY or may not need to have it narrowed. I don't know of any cheap options for putting a 9 inch under a pinto but many have done the conversion. The max torque an 8 inch will take (with slicks) is about 350 ft lbs. If you are running street tires only, an 8 inch will hold up for a long long time (read lots of tire smoke). I bought an 8 inch/9 inch large flange rear disc conversion on E-bay for $299. Pintos/Mustang II 8 inchers are small flange so you will need to modify the supplied plate some. No matter which rear you go with, the Torsen type geared Posi is the way to go. There is no better, period.
Do we know what breaks first when one exceeds that?  I'm already making 350 tq at the wheels on motor, and I sure would like to have it hook some day...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Uh oh.....
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
http://www.mustangandfords.com/how-to/chassis-suspension/mump-0008-ford-granada-9-inch-rearend-swap/
azz101462
well we managed to get a 408 stroked V8 with just over 420ftlp of torque so not sure the 8" will hold up for long, thus the reason for wanting to change to a full blown 9"
dennisofaz
Hi AZZ,
You already have a desirable 8" rear, no need to improve un less you want to have a lot of power.
Dennis
azz101462
I have a 1974 Pinto Wagon and looking to change out the stock 8" axle with a 9" posi with disc brakes, any suggestions would be helpful.
