72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 02/14/2018 01:34 am
Date: 02/08/2018 02:26 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 09/01/2017 07:52 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 10/26/2020 03:24 pm
Date: 09/19/2019 04:43 pm
  • Online today: 600
  • Guests: 544
  • Total: 544
Replacement floorpans for 76?
Started by powderblue76, November 05, 2015, 08:06:46 PM
powderblue76
Thanks for the 411.
MII, good call.
Do I assume correctly that I should use 18 gauge sheet?
I use a mustang ii panel on my 76 drivers side , the panel does not come back that far to the rear, you may have to get a yard that has a wrecked pinto that the floor is good and have them cut it out for you , much easier than to pound one out,
The Mustang II repop pans are supposed to be close but if you have a bead roller it would be fairly easy to make.
powderblue76
Need to replace the RR footwell panel in my 76, anyone make a patch panel, or am I to break out the bead roller and forming hammers?
