Date: 05/28/2017 03:20 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 08/22/2018 09:23 am
Date: 03/25/2019 09:02 pm
Date: 04/15/2017 05:14 pm
Date: 10/28/2018 08:45 am
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
  • Online today: 178
  • Guests: 142
  • Total: 142
three questions
Started by JoeBob, November 02, 2015, 05:53:18 PM
pintoman1972
Never drove a stock pinto.
9.98 seconds at 148 MPH in the 1/4 mile is my fastest run.
2 1/2 years to build.  More modifications than I can count
See my photo gallery
Every time I see a modern front bumper/lower valance torn off a car and lying at the side of the road I contemplate its adaptability (at least in part) to one of my older cars.  I mean, it's free for the taking and nothing but my time to tinker with it. Given that modern bumpers have are aerodynamically designed it might be a way to go.  The only thing is that it is a very fine line between looking cool and looking utterly stupid.
To add to 65SC's question about front lift..., he has the 2.3 turbo in an early car like I do.  I'm not sure if it is the extra power, or the springy aspect of the extra weight, but my car has a lot of front lift on initial acceleration and as I approach freeway speeds. The front end just seems kind of light and floaty.
76hotrodpinto
I've been sketching some designs for an air dam, with front brake vents. I like the idea of it, and the look, but I am torn. I also want it to look very plain and "innocent". It's funner to sneak up on them!
Behind Door #2
1000 ft climb in elevation, 18 corners , 2.375 miles , Standing start,  Elapsed time 2 minutes 28 seconds. Do the math.  IMSA RS Motor with dual DCOE 40's , Hooker Super Comp header, 3:40 8" Rear with Traction Lok Diff,  Firestone Slicks, 20" diameter, 9" wide on Panasport wheels.
On Level ground it would pull 7500 rpm and Scream, with street Tires, over 110 mph but you better have some stones to hold on to it. ;D
Older But not wiser than 1988 thru 1992.. The Lunatic is in the garage...
The first of my 16 Pintos was a new 72 plain Jane with a 2L and 4 speed. Any thing over 60mph was a real white knuckle drive. The only thing I did was to add an A&A fiberglass chin spoiler. The difference was like night and day. The car was glued to the road and very stable up to its max cruse speed of 70 mph. Made all the difference in the world. Sadly the spoiler is no longer being made except for the one up in Canada that is a real rip off. What I now use is abs plastic to make a flat air dam that is almost bullet proof. Form it with a heat gun. Speed bumps will not hurt it at all. Only problem is its a 4x8x1/8 sheet so you'll have a lot left over. About $100 a sheet from Granger.
"That reminds me, does anyone know if Pintos have a tendency to lift at that kind of speed? They look like they would and most cars from that era did, so..."
Back in the Pinto Pro Stock days the Pinto was said to be more aerodynamic backwards than forwards.  Not sure if that is true or urban legend.  One of the issues my Sunbeam Tiger group deals with is heat.  Apparently air moving under the car creates a high pressure area that limits the airflow out of the engine compartment.  Many have dealt with it not by having the typical wedge type front air dam. Rather the dam is completely vertical and forces the air around the car. This creates a low pressure area and allows hot air to escape the compartment.  Even the dam is low tech. They use the 6" black plastic garden boarder with the rounded top.  They slit the top, notch a few flat oval holes at the round base and use hose clamps to attach it to the sway bar.
If you look at the sides of our Pinto's they are quite tapered, especially for the time.  In this Pinto commercial https://www.youtube.com/watch?v=_0azX2k2AC0 they had a bunch of huge fans blowing on the side of the Pinto as it drove by to show its stability.  I guess with larger cars available they thought a selling point would be its cross wind stability.  Kind of ironic. Rumored to be more aerodynamic backwards than forwards. Displayed as being aerodynamic sideways I guess someone forgot to test it going forward - LOL.
76hotrodpinto
Hard to say. It buries the speedo pretty quickly.
And as for the air foiling, at about 75, I can feel the air hitting and lifting. If it were to be an issue, I'd say an air dam would just about fix that. And I think they can look good.
I had mine up to 80 one time and it felt stable, of course it was under ideal weather conditions too, could be a whole different deal with a head wind..
When my '72 2.0 was stock, I think I had it up to 70 or 75. It was a little buzzy for my liking.
I'd have to look at the data logs (because I was watching the road rather than gauges), but I think post-2.3 turbo swap may have been 85-90mph so far. I thought it was going take a bit of pedal to merge and suddenly I'm going a lot faster than the other cars. Nice surprise, but not with Pinto brakes.
Fun trivia: it's gear-limited to 143 @ 6000rpm.....but not gonna try it.
mechanic
the capri with the german 2000 handled really well and could do 100- 105 mph
LongTimeFordMan
1972 capri (similar to pinto) with modified 2.0, Isky cam, 10:1, holly 390 4bbl, header, stock body, trans and rear end..
75 mph in 2nd gear @ 7500 rpm, shocked the young fellow in the new porsche who couldn't seem to get past me... until I lifted my foot
never topped it out in 3rd or 4th
My stock '71 got up to 80 on the Kansas Speedway track during the first Pinto Stampede in 2011 (she was 40 years old)... and I've gotten her to 85 on the freeway here in Cali. My '74 Squire with 4-speed and 2.3 (also stock) I've gotten to 85 just last year. Both cars have their original engines/transmissions.
entropy
I didn't look, but I had a car and a half on the hotrodded 396 SS El Camino in the other lane.  Of what was a probably a racetrack. As far as you know.
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
PAPINTO
1980 wagon 2.3 4 speed bone stock as far as I know, needle stopped just before 85 garmon said 92. Still had a little left in her but my exit was coming up.
The Whistler
About 115 MPH stock with a 2.0.
Until the broken centerline in the road became solid and beyond Until 8000 RPM in fourth gear stock 4 speed and rear gearing with 2.3 turbo.
Turbo is a way of life
I routinely buried the needle on my brand new '74 Runabout back in the day.  That's what you did when you were sixteen!  With the two Pintos I've owned in more recent years (a '72 sedan 1.6L 4spd and my current '72 Squire wagon 2.0L automatic) I've held it within the speed limit which, on the Interstates around here, means 70.  All three of my Pintos were/are bone stock... I'm just not into modifications.
Dwayne :)
first new 1971 pinto, 2.0 four speed ,3.55 rear , top 105 , 1973 new pinto 2.0 four speed ,same 3.40 rear , top almost 85 , New 1974 pinto wagon, engine swap one year later , 351W with 10 to 1 pistons , 850 holley , top loader four speed , headers , crane cam, L-60 14s on back with a 9 inch rear, when past the 110 number on around to bounce on the zero peg , as for legal i have to say i do think the statue of limitations have long since pasted , but on the other hand 110 on my 76 V6 pinto , 2.8 stroked with a 2.9 crank , TBI fuel injection ,headers , and Not in overdrive ,
DBSS1234
Stock 1977 2.8 V-6, had the 85 MPH needle buried when the car was new. I baby it more now.
Had mine to 80mph(75mph speed limit)only did it once for a short distance because the motor was buzzin, just wanted to see how it handled..
JoeBob
How fast have you driven your stock pinto?
How fast have you driven your modified pinto?
How was it modified?
For the sake of propriety we will all assume that your speed was attained in a legal location!
77 yellow Bobcat hatchback
Deuteronomy 7:9
