Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 08/27/2018 11:11 am
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 11/11/2019 03:38 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 08/03/2017 07:40 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 09/12/2018 12:33 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 193
  • Total: 193
Hello Baby Blue
Started by t5gt40x, October 18, 2015, 08:56:15 PM
ricohman
Quote from: t5gt40x on February 18, 2016, 10:41:20 AM
I am certain it would. Im confused about this, but it seems those halfwindow hatchbacks are 71 only?
mine has a later hatch in back. heavy too.
I wouldnt mind finding the correct hatch for it, of only to see the weight difference!
If you have a cherry late Pinto and the option of picking up an early car to V8, especially a 71 take a crack at the early car and preserve what has
nicely survived. I thought the 74 on was more suitable, but now I see the light. they both work, the earlier cars have harder parts to source, but lighter weight and classic Pinto looks. If I can get my 72 wagon put together I will be looking for another 71. shoot me.
Yes is is a 71'.
I had a look at the car, but it has some rust issues with that hatch and one of the doors.
t5gt40x
Quote from: ricohman on February 05, 2016, 10:44:19 PM
Nice.
I am so torn on what to do with my time capsule 1979.
A 1.6 72" with that weird half hatch half window just popped up locally. Supposed to have 36000 miles. Maybe that would be a better car to mod.
ricohman
Quote from: t5gt40x on February 04, 2016, 06:52:05 PM
Nice.
t5gt40x
t5gt40x
thanks Reeves I will do that!
Crowed a little too soon there, the next morning it sprung a leak in cylinder head freeze plug, the rear. More than an excuse to see what was inside the motor. 2482 pistons appeared and a mystery cam (since I cant figure out this dial indicator mount to suss lift..) attached to stock rotator retainers and rail rockers with screw in studs and guideplates. Now that the heads are off I HAVE to grind the untouched exhaust ports before I can slide them into a machine shop. Probably new everything for a single coil hot hydraulic cam should do the trick. new freezeplugs for sure. Some krylon 1923 and back together with a single plane and better air cleaner.
oh yeah, dont forget to detach your transmission dipstick before pulling the head! what a mess.
Your headers are real close to your MC / rear brake line.
Which WILL over heat it : you need a heat shield & make sure you use dot 4 brake fluid (withstands heat better).
t5gt40x
I seem to have hit the jackpot. appears to have 3.80 posi 8". maybe even 31 spline, a Boss 302 oil pan and a lot of cam. A big Griifin radiator and a mechanical fan! held up under heavy traffic in warm weather too!
t5gt40x
t5gt40x
ill figure out how to post correctly...
