78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 03/13/2021 12:57 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 08/16/2018 08:54 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 06/24/2020 06:12 am
Date: 02/27/2017 10:10 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 1,166
  • Guests: 519
  • Total: 519
Stalling problem
Started by JoeBob, October 17, 2015, 12:06:01 PM
C. M. Wolf
I would recommend checking the fuel pump, 2.3's were a bit notorious for weak fuel pumps. I finally placed an electric fuel pump in my 77 Porthole way back when.. solved the very problem you describe.
Easy check.. at the times it stalls, open the fuel line to the carb to see how much fuel is there, if it pumps fine(it's mechanical & should pump simply by turning the engine, running or not).. if it still pumps fuel, check the electrical for an intermittent short.
Since there are basically two types of electric fuel pumps, those that draw well but pump moderately, and those that tend to rely more on gravity to then pump better, I picked the latter and mounted it back by the tank.. I also ran the fuel pump switch through my hidden kill switch to help keep it from being stolen as easy. ..worked great after that.
Michael
JoeBob
My 77 bobcat 2300 stalls without symptoms. I am driving and the engine stops. I pull to the side of the road and turn the key. It starts right up. The next time I just down shift and pop the clutch on the roll. I should start, yes. No! I roll to the side of the road and turn the key, bingo. Next time It stalls I turn the key off and on again wile still rolling, It starts.
It may stall every five minutes or not for weeks. Any ideas?
77 yellow Bobcat hatchback
Deuteronomy 7:9
