72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 07/01/2019 03:17 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 07/11/2023 11:39 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 07/10/2016 10:17 am
Seeking parts
Date: 10/18/2020 10:35 am
Date: 02/08/2018 02:26 pm
  • Online today: 600
Th400 swap
Started by mustang408, October 11, 2015, 11:05:21 AM
DODGE torqueflite tranies were used in early funny cars and worked great. Still being used in drag car today.
entropy
What about a Powerglide and a Gear Vendors overdrive unit?
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
mustang408
Quote from: pinto_one on October 15, 2015, 11:40:54 AM
A TH400 would be a strong trans and I know you do not want to cut the car up which leads to other problem alone the way , C-6 is kind of long , I had to move my trans mount back 4 1/2 inchs to use the A4LD overdrive on my V6 and even hated to cut out the whole trans mount to fit it, the trans i was going to use was a 700R4 and made a bellhousing to fit the V-6 , but the long tube headers hit the front servo piston and did not want to even cut those headers (looked for years to find them) the trans was shorter than the Ford overdrive and the plus it had a 3 to 1 first gear and overdrive , i am only posting this since you say you drive on the street and thought you might want to keep the rpm low and mpg a tad higher when you runaround , and can you post more specs on you engine and mods , 9s in a street pinto is great , R & D to get that takes time and money , Cheep R & D is Rob and Dupicate  :o
Thanks for the info. I've had a chance to do some measuring of a friends th400 and looks like it should fit with minimal cutting but will be super tight and I will have to make a mount. Here is some info on my Pinto.
The motor is different from the original build when I bought it. I broke two pistons last year. I took all my best parts and put this motor together. The motor is a 1985 351w .030" over block, forged eagle crank and I beam rods stroked to 383. It also have custom Ross 8 5 1 pistons built for boost, the ring package is a lot lower. The cam is a FTI billet custom cam with morel link bar roller lifters. Heads are twisted wedge fast as cast 190cc with PAC ls style springs and has trick flow roller rockers. The intake is an edlebrock performer and has a CSU holley 750 blow thru carb. I added a msd 6al2 programmable for boost retard, these boxes are worth every penny. Fuel is an aeromotive a1000 and boost referenced regulator.
For transmission right now I have a fully rollerized redneck c4 with transbrake and a PA 9" 4000 stall. Swapping in this stall from the original was a night and day difference. The rear end is a 9" with custom 4 link 3.00 gears.
The turbo setup is T04e 60 trim p wheel, A/R: 68 / .50 running 10 psi on 94 octane and meth injection. The car is an animal lol. Ill be upping the boost when I get a good trans. I've had to add a drag wing and front spoiler to keep the car stable on the top end. Any questions please ask.
Next year will be my pinto engine into a Pietenpol (airplane) .
76hotrodpinto
You do some very cool builds!
mustang408
Quote from: Wittsend on October 12, 2015, 11:29:37 AM
Mustang408, thank you for the added information.  It is helpful to understand your situation.
To the other Pinto posters. I believe "Mustang408" is looking for anyone who had done the 351 (383) / TH400 installation into a Pinto because his greatest interest is how much transmission tunnel modification (if any) is needed.  He seems to have all the technical aspects down as to what he wants. He is just tired of fixing the C-4. The TH400 being an engine used behind GM big blocks is know for its strength and at this stage reliability seems to be his highest priority. So, if anyone knows of a TH400 install in a Pinto... .
Thanks for clarifying things for me to everyone. The th400 is the strongest production 3 speed trans out there. That's why i want to use it. If I have to cut the tunnel out I will go glide because it will fit. Im ok with a bit of modifications to the tunnel but don't want to cut the car to pieces.
Have you looked at the ford Overdrive trans for the 5.0 , fellow i know that has one in a pinto with a built up 5.0 and been working well over the years with no trouble , since you drive on the street it extra gear will help with the gas mileage and engine wear, last would be a ulta bell bellhousing so you could use the 700R4 trans on the ford engine , known to hold up to big blocks , but i would check with PAT transmissions to see if the ford overdrive is up to specs for HP output ,
A TH350 would be more practical, not as big and less weight and take less HP to run than a 400, and can be built to take a fair amount of torque easily on a budget(especially with a small block), and a lot nicer to drive on the street than a PG. JMWO...
mustang408
Its 78pinto's old car. He was a mod here that passed away a few years ago. Great guy. I think the original build was well documented here that's why I posted the video. The combo has changed quite a bit now. It has a 351w stroked to a 383, twin turbo and a redneck c4. My combo has out grown the c4 so its time for something a bit more reliable. I'm constantly fixing it.
I'm not looking how to do the swap. I was hoping maybe someone with a Pinto had done it and had some feedback on if I need to do a lot of cutting or if it fit as is. Not looking for a how to, just a confirmation it will fit without major cutting. I know there are tons of cars that it will work in but cant find anything pinto specific other than the ones that have been cut to pieces and tubbed. I figured where else to ask, this is a Pinto site. Thought maybe someone may have done an ls swap or something. Anyway if anyone has any info please let me know.
It would be helpful to know what engine you are running.  The You Tube video "sounds like" a V-8 and the 408 in your user name incline towards that too.  But, we can only assume.  Most here drive stock or relatively stock Pinto's. Others go with the 2.3 Turbo for performance though there are a few with V-8 swaps. And, most of those likely run a C-4 if an automatic.  If you in fact have a 408 I'd assume it is built off the 351  block?  What is it others run for an auto trans with that engine?.  While there are a few V-8's here and perhaps a few racers I'd think a sites that are more inclined to be powered by the Ford V-8 would likely have a more ready answer.
mustang408
I'm torn between the two. I do street drive it as well.
72pair
Most of the really quick cars I see are running powerglides. Lots of good parts available and lightweight.
mustang408
Looking to change to a stronger transmission than the rollerized redneck c4 I have so I'm not pulling it out and freshening it all the time. Anyone swap in a th400 into a Pinto without cutting it to pieces? I own 78pinto's old car but the new combo has out grown the c4. Twisted the hardened input shaft the last time at the track. Ran a 9.78 but no mph reading as it wasn't working but usually trapping 143mph.
Here is a video from the private track rental I was at if interested.
https://youtu.be/nkJSfd-bdhg
Any info would be great.
