Date: 06/05/2018 09:13 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 04/30/2023 04:31 pm
Date: 06/24/2020 06:12 am
Date: 03/30/2021 12:29 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 07/08/2017 08:53 pm
Date: 01/23/2023 02:22 pm
  • Online today: 1,166
  • Guests: 467
  • Total: 467
15" tire clearance question
Started by shuffln, October 07, 2015, 10:35:41 AM
shuffln
Yeah its close just like a mustang ii
entropy
Quote from: shuffln on October 07, 2015, 06:23:02 PM
I know the ture doesnt sit in the middle of the wheel well but how much room should there be
225
You're fine.  Hell, one configuration of my car is running 235/60s in the back and 225/50s in the front.  If anything, you're cutting it close on the back side of the tire.  Probably not a lot of room between the sidewall and the leaf spring, right?
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
shuffln
The Whistler
I have used that tire size for years with no issue
Turbo is a way of life
shuffln
So i just added a set of 15" centerlines with b.f. Goodrich t/a's. 235/60/15 on them. Im a little concern on how close they are to the rear 1/4 panel
