Date: 12/09/2018 06:59 am
Date: 01/06/2017 11:42 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 07/08/2022 11:51 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 1,166
  • Guests: 130
  • Total: 130
Still pondering the many rear ends of the world.
Started by 76hotrodpinto, October 05, 2015, 03:45:24 PM
82expghost
i would love to see pics of a pinto with a little camber and some rear wheel meat
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
76hotrodpinto
I went with the jag for the parts availability as well(aftermarket). The mods to shorten it are pretty straight forward, and easy with a lathe.
82expghost
i fogot to mention the xr4ti rear end, also a drop out unit........ and i have already tried fitting it in, the car will sit significantly lower, just warning
82expghost
the jag rear end might not be the way to go unless you like having a 5x108 lug patern and want to run taurus wheels, a toyota irs might be the better choice, better axles, better rear end, mustang lug patern, lighter, needs more fab work, many more plusses, lexus also uses the same rear end, if you want to have chevy lug patern, bo with a bmw rear end swap from a early 90s 5 series or late 80s, it will be a drop out unit like a ford, but has way better geometry for your handling pleasure
76hotrodpinto
2 problems with the pontiac irs.
A. It's a gm product. I don't really have a favorite brand, but I do have a least favorite. Around here, gm is something you might step in and have to clean your shoes!
B. I have doubts about the parts availability.
one2.34me
My brother just bought a really nice 2007 Pontiac Solstice GXP, 5 speed with an independent rear suspension. The car is rated at 260 horsepower, so that rear end should handle most Pinto apps. Could that suspension be modded into a Pinto chassis? It's a pretty new car and I don't know how many Solstice/ Skyes were made to pick parts from, but, it may be something to look into.
76hotrodpinto
Yeah... all the ford irs units I've seen are just huge heavy bulks. I'm fully decided on the 55" jag. It's proving hard to find, but they are out there, just most have been worked or restored already, and want more money than I'm willing pay.
I did find a mounting cage for one, so I'm working on my subframe design to accept it. I was also looking at an acura(i think) irs, and it looked like it would be a pretty good option too, but I can get a wide variety of cool stuff for the jag irs.
one2.34me
"Looks kinda heavy????.."
X2^ Plus bags, springs, shocks?
5.0 Chero
Braindead
I was under the impression that the Ford IRS sets were not removable as a unit. The attachment points are all integral with the unibody construction. If not, count me in with that idea!
patcosca
I've been pondering a IRS swap myself.  First started looking at the T-Bird 8.8 IRS, then to the 03/04 Cobra 8.8 IRS, and lastly been looking at the 2015 Mustang IRS.  I really like the 2015 but they are harder to find.  Depending on what you're going to do with it, one of these may be another solution.
76hotrodpinto
Hmm. I guess I set that one up pretty well!
I think I have a line on a 55" jag assembly. It's about 100 miles out of town though. The 61" seem to be plentiful, and reasonably priced, but 61" is wider than I'm willing to go. For the money though, posi, disc brakes and independent suspension, all for about $500 and a some mild fab work? I'm really leaning towards doing this.
We now return the topic to the gutter... ;)
Can't tell you too much other than they (Salisbury) are basically Dana 44 center sections.  I think too the ring gear bolts are a different size from the Danas but they make stepping bolts to deal with that. My Sunbeam Tiger has a Salisbury. Now, how you adapt the IRS in is another story. The good news, at least here in So. Cal. the self serve yards are full of Jags. Still not sure I can picture a Pinto with negative rear camber though.
Quote from: joebob on October 05, 2015, 06:09:43 PM
I have been pondering rear ends since I reached puberty.
Glad to know I'm not the only one!!! ::)
Same here , but don't let your wife find out or she will break your axle ,  ::)
JoeBob
77 yellow Bobcat hatchback
Deuteronomy 7:9
76hotrodpinto
I keep flip flopping on my plans for the rear end, BUT NOW... I'm liking the idea of "throwing" a jag independent suspension rack back there... I think. I don't know much about the jag, but from pics, it looks like it's easy to fab in. And since I don't have a fuel tank down there, I have the room... I think.
Anyone hear put a jag rear end in anything? Have any more pro's or cons to add to my equation?
I think It would be the beez kneez!
