Date: 10/24/2019 01:43 pm
Date: 12/20/2016 10:47 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 11/11/2019 04:49 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 1,166
  • Guests: 482
  • Total: 482
Transmission modulator valve/ vacuum question
Started by pinto bismol, September 26, 2015, 11:26:32 PM
Also check the pin they come different lengths, 1 1/2 to 1 5/8", short pin early shifts, long pin later shifts, you can make them out of 8D nails and experiment with them. If you have a screw in Mod I believe the min length is 1 5/8 and max is 1 3/4", if my feeble mind remember right..
The one you have may be adjustable, look on the very end and see if you have a small screw half sticking out , the stripes are for different shift points due to different reared ratios,those are non adjustable  , (engine loading =high or low manifold vacuum)  if you use the wrong one you may end up with a early or late up shift , they have a calibrated spring inside , stiff spring late shift , soft spring early shift
pinto bismol
I'm wanting to put a new one on my 76 2.3 automatic, but napa has one with a red stripe a yellow stripe and a green stripe. The one on my car now has NO stripe.....what gives??
Caution.....explosive personality!
