1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 01/24/2021 07:54 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 02/18/2017 04:41 pm
Date: 01/12/2019 10:19 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
77-78 front grill
Date: 04/07/2017 12:35 am
  • Online today: 1,166
  • Guests: 453
  • Total: 453
need a rear sump 2.3 to be a front sump
Started by rowdyrunabout, September 21, 2015, 06:43:25 PM
rowdyrunabout
dont worry about cutting the stud off the bolt , just swap it to the front main and torque to 90 ft lbs , on the dip stick you can dump in 5 qts of oil , new filter and run for a min , check with the dip stick you have , if it does not touch you use a tubing cutter and cut the tube shorter , alittle at a time , until reads full , if the stick reads to high remark the stick with a file , do this if you can not find the one you need ,
76hotrodpinto
I just did this. On mine there was a oil pick up tube mounting bolt on one of the main caps, the front sump won't clear it. You need to either get another main cap bolt, without the mount on it, or tape off the open case and motor to cut it off. Tape it VERY well.
And the dip stick for the rear sump sits at a different level than at the front. I had both sticks and used the one the came with the front sump, but the difference between the ones I have is only in the tube, not the stick. The front one had only one maria(the stop point formed in the tube), the rear sump one has two marias. The bottom one being for the rear sump stop length, and the next one lined up perfectly with the front sump one. Meaning you can cut off the tube, just above the first, and should read correctly for the front position.
rowdyrunabout
Well that would just be too easy! I'll take a look- Thanks.
There should be a small plug near the fuel pump , when you change the pan knock it out from the bottom and put it in the rear old location, the block is already drilled for it ,
rowdyrunabout
I recently found a complete 78 2.3 motor with about 60k on it. I also picked up a 78 cruisin wagon with no motor. Thought I had a cheap route to getting the pinto back on the road quickly. The motor is out of a mercury zephyr and has a rear sump oil pan. How can I make this motor work in my pinto. I understand that I'll need to change the oil pick up and pan. WHAT do I do about the oil dipstick being in the wrong place on the block? Thanks.
