Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 01/04/2017 04:07 am
Date: 09/15/2019 12:28 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 08/24/2018 02:50 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
  • Online today: 1,166
  • Guests: 483
  • Total: 483
Going to roller cam
Started by righthandman, September 21, 2015, 04:40:39 PM
From everything I have read, the Ranger roller cam will not provide a noticeable difference in horsepower.  It is a good reliability upgrade, chance of wiped lobes is greatly reduced.
The 94 Ranger should have a roller cam if it is stock.  Some where between 94 and 95, Ford went from 11/32" valve stems to 7mm.  The 7mm rockers will not fit over the turbo head's 11/32" valve stems without machining/grinding.  The 7mm roller rockers are identifiable by their stamped metal construction versus the earlier 11/32" roller rocker's cast construction.
righthandman
 Been thinking of putting a roller cam in my turbo 2.3.
I guy close by has a 94 Ranger engine with the 8 plug head. Do these have roller cams and if so this cam will work in my turbo head right?
Would I feel a difference in horsepower or how much? Thanks in advance.
