Date: 04/20/2017 10:10 am
Date: 08/05/2018 01:58 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 01/24/2017 12:36 pm
Date: 02/18/2017 04:44 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 08/30/2021 03:20 pm
  • Online today: 1,166
  • Guests: 497
  • Total: 497
cowl help....
Started by D1, September 07, 2015, 06:14:16 AM
If your cowl isn't rotted & you just want to clean & paint it up in there pull the heater box & drivers side vent & you can reach most arms if your arms are long enough. I did my 80 this way & wire brushed the painted it all without looking.
My 73 was a different story as this shows.
  http://www.fordpinto.com/index.php?topic=19089.0
D1
Ok.....so the cowl is something that does not unbolt to remove to get to wiper arms etc......so how in the world do you suggest I get in there to clean sand and paint underneath it....I thought about cutting it out doing the work them welding it back......but when welding, this will cause welding beads/slag to possibly get on the new paint underneath.....then while sanDing and painting the rest of the car, over spray etc. will get under it....HELP!!!!   signed CONFUSED PINTO IDIOT IN MS.
Thanks
May the Lord bless
Romans 14:11(KJV)
