Date: 07/20/2017 01:23 am
Date: 07/08/2017 08:25 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 05/24/2020 08:19 am
Mirror
Date: 04/15/2020 01:42 pm
Oddsnends
Date: 12/20/2016 10:52 am
Date: 08/22/2018 09:23 am
  • Online today: 905
  • Guests: 408
  • Total: 408
Pinto questions outside storage
Started by sedandelivery, August 30, 2015, 12:41:42 PM
C. M. Wolf
I'm guessing that you live in an area that might get snow or at least freeze..
1st, make sure you get a battery maintainer on it.. and plug the block somehow into a heating sys so it doesn't freeze & cause damage from ice internally.. Using either a magnetic oil-pan heater or a block heater that is installed into one of the engine's freeze-plug locations is best.
2nd Cover the car with a good, soft-lined car cover that won't allow water through it.. or cover it a second layer with a cover that won't allow water through. Also make sure you have a good 'sub-zero' anti-freeze/coolant in the radiator sys, or totally drain it if it's not going to be driven.
Reducing the air pressure by 5 lbs on the tires in a freezing winter couldn't hurt, but make sure they have good pressures when driving again.
The engine thermostat & heater sys should be in good working shape, & make sure the heater fan works.. even in hot summers, a good heater sys can help keep a vehicle from over heating by acting as a secondary cooling sys for the engine, even if it's very temporary/short term(it's just very uncomfortable in the summer to have to run the heater too).
IHTH ;)
C. M. Wolf
sedandelivery
This summer I have been fortunate enough to be able to drive my Pinto delivery van more than previous years. Every where I go the past couple weeks people have asked me what is it, their family had one, etc. This morning at the Farmer's Market I was barraged with questions. Kind of nice, but I have to make extra time to go places! I have to leave it outside this winter, need some storage tips for outside storing. It is 95% rust free and I want to keep it that way!
