Oddsnends
Date: 12/20/2016 10:52 am
Date: 04/15/2017 05:14 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 02/18/2017 04:47 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 11/11/2019 03:38 pm
Date: 02/27/2017 10:10 pm
  • Online today: 533
  • Users: 1
  • Guests: 480
  • Total: 481
anyone installed a t-5 trans
Started by RAGINGPINTO, July 31, 2005, 10:02:20 PM
TonyB
It also depends on which T5 you have....A t5 from a 2.3 will bolt right in.   A T5 from a V8 needs the input shaft modified...i.e. the pilot bearing surface needs to be ground down as the v8 uses a larger pilot bearing.   I have done this on mine.   You still need the bellhousing from a 2.3/T5 to mate to the 2.3 in your car.   I have heard several rumors that there are a few different bellhousings available, but cannot confirm.
HTH
Tony
'72 Pinto Runabout, 2.0, Big Valve head, T-5, 8" w/ 3.73 Posi.   Currently awaiting $$$ & Time
CHEAPRACER
Quote from: Pintony on August 01, 2005, 08:15:37 AM
Hey CHEAPRACER,
My speedo cable was way too short.
Maybe a difference in years of the Pinto????
I did my swap on a 1972 sedan that was originally a 4 speed.
Maybe the automatic tranny has a longer cable?????
Lets figure this one out.
I love this group!!!!
You got me on this one but I will tell you how lucky I was to get a 3:55 geared TurboCoupe and a 3:55 geared 8" rear. It made my speedo perfect with the size tires I run. Now if I can get off my butt to hook up that backup light so I won't run into my fence at night...thats another story.
RAGINGPINTO
My car is a 1980 with the 2300 and the 4 speed any one got a 8inch rear to sell or trade or even gears for the tiny 6.75 rear end because I got 273s in my car, I want at least 340s or lower to go with the t-5 trans
1980 pony Holley350 cfm 7.5inch rear posi almost rust free
Hey CHEAPRACER,
CHEAPRACER
Quote from: Pintony on July 31, 2005, 11:50:52 PM
You will also need the speedo cable from the mustang.
??? I used the same cable and part that inserts into the trans from my original 4 speed but used the speedo gear from the t-5 to match my new gear ratio. My t-5 came with the electric speedo if this makes any differance.
Hello RAGINGPINTO,
If you have the 2.3?
It's pretty straight forward.
You will need to modify the stock Pinto crossmember.
Hang your T-5 and then hold the mount so the U goes toward the rear of the car and mark the place where you need to put the NEW holes.
+ the correct yoke. and a U-joint to connect your driveshaft.
LMK if you need any more help.
RAGINGPINTO
I recently purchased a t-5 out of a mustang and I was wondering if any of you could tell me if i need to do any modifying or if it is a direct swap? any help is appreciated. ??? :-\
