Date: 07/08/2022 11:51 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 02/28/2024 02:07 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 03/16/2017 10:00 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
  • Online today: 1,166
  • Guests: 467
  • Total: 467
visors
Started by JoeBob, August 03, 2015, 05:55:46 PM
Its friction that holds them in.  You will need to get out the broken piece from your existing visor.  I drill a hole and then screw in a long sheetrock screw.  Then take pliars and pull on the screw head.  It may come out on one shot or you may have to drill and pull a couple times.  It just depends on how fragile the plastic is.
To remove a good pin, I take a rag and some pliars and pull.  You have to make sure the rag is thick or you will mar up the plastic.  Else if you do not care about the doner visor, I would just cut the metal shaft out of the visor and pry the tube apart to release the pin.
Then you need to go to one of the early Mustang parts suppliers and buy some new rubber ends.
Good luck
JoeBob
The stick in my visors is broken. Got some from the junk yard , wrong color. I do not know how to remove the stick. I don't want to pull hard for fear that replacements are fragile. How are the sticks held in place? How do I remove them?
Thank you
77 yellow Bobcat hatchback
Deuteronomy 7:9
