Date: 02/04/2018 08:26 am
SVO SWAP
Date: 03/15/2018 03:12 am
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 12/31/2017 11:14 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
  • Online today: 525
  • Guests: 188
  • Total: 188
WILL TRANS.FIT?????
Started by 74PNUT, July 29, 2005, 01:17:51 AM
74PNUT
I HAVE A GOOD 4 SPD TOO.JUST THOUGHT AN AUTO WITH STALL CONV. OR 5 SPD.WOULD BE COOL!! DOES THE 4 SPD.TRANS HOLD UP TO DECENT POWER ???    THANKS FOR THE INFO.
mcrouthamel
I have available 2 4 speed trannys for a 2.0 if interested in giong this route.
Mark
mcrouthamel@netcarrier.com
Hello 74 P-NUT,
The problem with the 77 tranny is it is most likely a C-3 tranny.
They are JUNK!!! AND very expensive to rebuild so you do not want to go there. >:(
If the 77 tranny is still in the car and you can check the door post for the I.D tag?
Look under the tranny code IF it is a W then the 77 tranny is a C-4.
IF you have the W then you can remove and just swap the bell house.
If the tranny is already out of the car???????
If you post a photo of your 77 tranny SIDE VIEW I could tell you what you have. :)
The C-3 tranny has a different bolt pattern as it bolts to the back of the 2.3 head not the block.
As far as the T-5 goes I have a T-5 in my 72 pinto. from a 87 mustang I had my bell cut and welded to make the bolt pattern match my 2.0 engine.
TurboPinto72 made some cool brackets to mate his T-5 to the 2.0.
Maybe you could ask him for advice???
74PNUT
WELL THAT'S JUST MY LUCK!!!!I HAVE A 2.3 WITH GOOD TRANS.AND 2.0 WITH BAD TRANS.   OK,HOW ABOUT THIS??? I HAVE A 5 SPD FROM 87 STANG 2.3. I REALLY WANT TO USE THE 2.0.CAN THAT TRANS BE USED ???CHANGE BELLHOUSING???  I ALREADY HAVE THE PEDAL ASSEMBLY.  THANKS.
vonkysmeed
2 different blocks and I do not believe that parts are interchangable.  It might work with the propere bell housing, but I am not sure
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
74PNUT
WILL AUTO TRANS FROM 77 2.3 BOLT UP TO A 74 2.0??? THANKS.
