1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 12/09/2018 11:35 pm
Date: 06/24/2020 06:12 am
New cam
Date: 01/23/2017 05:11 pm
Date: 03/23/2018 09:23 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 08/26/2018 06:35 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
  • Online today: 489
  • Guests: 188
  • Total: 188
Clutch Cable '72
Started by TonyB, July 28, 2005, 09:38:52 PM
TonyB
PINTONY,
Thaks for the reply.   Spoke with a mustang buddy....Apparently the 80's 'stangs use a ball type end on the pedal side (and clutch fork side) of the cable.   Should work ok.   I'll let you know when I get that far.   Still waiting for phx to cool off.   Got another 2 months to go before I can work outside (for long perionds) again.
Thanks!
Tony
'72 Pinto Runabout, 2.0, Big Valve head, T-5, 8" w/ 3.73 Posi.   Currently awaiting $$$ & Time
Hey Tony,
I am a EARLY Pinto guy, BUT if memory servs then yes the 74 cable will work.
You will have to remove the plastic nut that will come on the 74 cable and put the nuts from your original cable on.
Has been a while since I even had the STOCK Pinto 4speed. I'm running the Borg Warner T5.
TonyB
Does anyone have a source for a '72 2.0 clutch cable?   Will one from a '74-80 pinto work?
Thanks!
Tony
