78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 10/24/2018 07:35 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 08/09/2018 07:49 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 06/12/2018 08:18 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 02/18/2017 05:55 pm
  • Online today: 1,166
  • Guests: 473
  • Total: 473
write up on adapting 75 turn signal switch to 71 pinto plug
Started by biggrgivens, May 24, 2015, 05:48:09 PM
According to the wiring diagrams I have, the 71 and 75 Pinto turn signal switch wire colors should be near identical, not sure about the plugs.  Both years show a total of 9 wires.  After 40 years, the wire colors tend fade and/or shift color some.
W-LB:  RH dash turn indicator
W-LB:  RH front turn light
LG-W:  LH dash turn indicator
LG-W:  LH front turn light
LG-O:   LH rear turn/stop light, (early 71's used LB-O, this is only difference found between early 71 and late 71 & 75)
O-LB:   RH rear turn/stop light
LG:      brake pedal switch
W-R:   emergency flasher
LB:      turn signal flasher
I swapped out my '73 Pinto column for my '88 Turbo Coupe column. In the process I had to trace down the wires. Here are my notes (use at your own risk) Maybe this will help though I'm not sure if the '71 and '73 used the same color code and if those colors changed after the connector. I did notice that even 15 years later a fair amount of the color code was the same for the '73 and '88 columns.
Curved connector
Black/pink - I have noted that it is activates the key buzzer, not sure beyond that
Light Green - I have as brakes with a question mark???
Blue - I have as the radio in the accessory position.
Orange/blue - I have as passenger rear
Green/red - I have a drivers rear
White/red - I have as flashers/emergency
Yellow/blue - I have as hot full time for the horn and emergency flashers
Dark Blue - I have as the horn
White/blue - I have as Passenger front
Light Green/white I have as drivers front
Maybe that will help though I'm not sure if the '71 and '73 used the same color code and if those colors changed after the connector.
Rectangular, black connector
Purple/white - Brake warning
Black/green (thick) - Accessory
Red/blue - Start
Red/green - Run
Yellow (thick) 12 volt in
Black - I have "all small lights" but don't recall the meaning
biggrgivens
I can match up 6 of the wires by color code, but I cant figure out the other 4 wires. Is there a write up for splicing the 71 plug to a 75 turn signal switch and harness. All help appreciated.
