Date: 07/30/2018 04:32 pm
Date: 01/06/2017 11:42 pm
72 Pinto
Date: 03/07/2019 12:07 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
2.8 radiator
Date: 10/25/2019 04:10 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
  • Online today: 1,166
  • Guests: 464
  • Total: 464
My '79 Pony Needs a Intake/Carb Update. Help.
Started by Natedawg63, May 18, 2015, 09:16:54 AM
Natedawg63
Found what I needed on the Ranger Station. Thanks for the replies and the concern of my skills level :)
Different engine, the intakes do not fit.
Unless the car is a California car with feedback carb the carb can be rigged exactly like an earlier one. The carb IS a Weber, just after Holley and Motorcraft got through with it. You're not smart enough to turbo or V-8 if you cannot figure out how to rig to drop the vacuum lines. No insult intended at all but the truth of it.
If no hi-perf parts then you are limited to the stock intake. You have a 2.3 motor in that car and a better motor than 2.0 in my view. Of course I will get some flak on that.
Pintocrazed
Natedawg63
Are '71-'74 2.0 single side draft carb intakes worth fooling with? Looking for a 2.0 so I can use a decent Weber carb or other early 2bbl carb w/o all the pollution crapola.
Thanks!
Natedawg63
I picked up a 1-owner Pony this past weekend and did lots of general maintenance on her. Alabama is not a smog State, so the smog pump is gone. Got her finished Sunday and seems the alternator is also shot... would not keep my brand new battery charged :(
The factory 2-barrel is shot... the little linkage on the butterfly valve is non functional and it is jus generally shot from sitting for years w/o running.
I want to replace the intake and carb, but nothing high-performance since I am gonna drop in a turbo or V8 at some point soon.
I jus want a setup that does not use 30 yards of vacuum tubes like the '79 does. I guess I need a pre-smog era intake carb but this is my first Pinto... so I am not up to snuff on what to look for. Any help is greatly accepted. Need to get her up and running :)
Thanks!
Nate
