74 pinto
Date: 09/11/2016 06:32 pm
Date: 07/13/2018 02:21 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
windshield
Date: 04/14/2018 08:53 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 09/20/2018 11:01 pm
  • Online today: 382
  • Guests: 363
  • Total: 363
76 2.8l swap
Started by Randy Holman, May 09, 2015, 10:31:38 PM
Quote from: pinto_one on May 16, 2015, 09:58:43 PM
knock knock who's their , Rod ,   Rod who,    Rod outside the block thats who,
I had a Honda Civic back in the 80's that sang that song!!!
Too bad you do not live near me , I got one that works when I replaced it with a A4LD overdrive , hard knock is letting you know you had better do something very soon , like knock knock who's their , Rod ,   Rod who,    Rod outside the block thats who,
LOL
Randy Holman
I'm doing the swap due to a shot tranny and a hard knock coming from the low end of the motor.
76 pinto wagon
Quote from: Randy Holman on May 09, 2015, 10:31:38 PM
Thinking about swapping my 76 wagon 2.8l with the c3 auto. Wondering what would be a cost effective, reliable, fairly easy, maybe even more power swap for the engine and transmission. What would you all recommend. Open for just about anything. This is my daily driver so the swap would have to be done over a weekend, crazy I know.
So a power increase is not necessarily a reason for doing the swap? What is your reason for wanting to do a driveline change?
Quote from: pinto_one on May 10, 2015, 12:16:11 PM
if your looking for more power you can do a easy up grade, find a Murkur Scorpio with the 2.9.and use your oil pan and engine mounts on it, yes it will bolt to your org transmission, as is it 40 hp more than the 2.8, you have add more if you can get the overseas computer up to 160 like it is
Computer? I don't think an EFI conversion and and engine swap are going to happen in a single weekend. The 2.9 with a carburetor is probably a good option here though.
A weekend , well that depends on what you have on the car and how much power you want , best if you got a engine ready to go to drop in, a weekend is possible , other things that take time to hook up if you have them, like power steering , A/C compressor and mounts, if your looking for more power you can do a easy up grade, find a Murkur Scorpio with the 2.9.and use your oil pan and engine mounts on it, yes it will bolt to your org transmission, as is it 40 hp more than the 2.8, you have add more if you can get the overseas computer up to 160 like it is, the intake will clear the hood , the Ranger/Bronco II will not, also you do not have to set the valve lash , it's hyd , these engine with care ,oil changes , and coolent maintenance will run over 300K , and one that surpassed that in a bronco II, and if you can grab the trans also , a great mod for mpg and quiet on the hwy , later Blaine
Randy Holman
76 pinto wagon
