Date: 08/22/2017 09:21 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 08/26/2018 06:35 pm
Date: 07/08/2022 11:51 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 08/01/2023 06:53 pm
  • Online today: 1,166
  • Guests: 541
  • Total: 541
Exhausts for Pinto
Started by Fern_Bern32, April 25, 2015, 07:57:46 PM
waldo786
I would like to go to a 2.25 exhaust and have a ranger header I plan on using.  I also got a Walker quieflow muffler as I don't want it to be real loud.
*Sounds*  ;D like a good candidate for use of a Helmholtz resonator to cancel the drone frequency.
I had an '89 Mustang with Flowmaster 40s and it droned in the same RPM range. It got even worse with an offroad x-pipe and headers.
While not a 4 cylinder Pinto, I have a single, 3" Flowmaster 50 ("suppose" to be a quieter 3 chamber muffler) on a 318 Valiant.  The DRONE comes on at 1,900 RPM and stays until 2,600 RPM. Right in the normal driving range.  It is so bad (No, not bad, HORRENDOUS) that it truly alters your senses. It is like a sonic warfare device. I vote a big NO for any chambered muffler.
Personally, I think chambered mufflers like Flowmasters sound funky on fours and only okay on sixes. They also have a universally bad tendency to cause interior resonance(drone).
A 2.00-2.25" exhaust with a matching "performance" turbo muffler will probably sound decent without being too loud
I'm putting a 3.00" system on mine with a straight-through muffler.  :o
76hotrodpinto
Rather than just throwing a cherry bomb on there, I'd recommend a header. The money will be better spent, as you get better performance, not just less back pressure. If the current system is just old, and it's time to replace it, do a header with a flowmaster type can, matched to a diameter compatible with what your motor needs to breath.
If you want it loud, just remove the muffler and stand on it.
78_starsky
I will trade you problems  I have duals that ran into glass bottles then into a set of mufflers and dump under the mid of the underside floor.  it is pretty loud and there is no room to make a nice affordable set-up that exits from the back.
as for what you are asking maybe a bit more info might help.  what motor? what you have running now? and probably any muffler would fit in the stock place for you.
Fern_Bern32
I recently got a 77 ford pinto in great condition. But I want to change the exhaust so itd be louder but don't know what kind of exhaust I should swap it with. Need help deciding. Thanks
