Date: 02/25/2017 08:45 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 05/13/2021 05:33 pm
Date: 05/22/2018 01:54 pm
Date: 10/05/2017 02:26 pm
Date: 03/06/2017 01:19 am
Intake manifolds
Date: 03/06/2021 03:04 pm
Radiator
Date: 05/27/2018 06:07 am
  • Online today: 129
  • Guests: 105
  • Total: 105
lower window trim .
Started by L.D, April 19, 2015, 01:52:09 PM
Sway bars are the same although some require the frame mounts to be moved a little forward. Better choice would be a Mustang II V-8 bar as some had a 1" bar up front. Stay away from a Mustang II rear bar UNLESS you can get all of the mounts. Sound like your car is going to be really ole school. I love it!!!! What wheels are you going to use? I hope its Libras. Look up "Wheels of Steel" out in your neck of the woods for steel wheels if you go that way. Keep in touch Tachi.
L.D
Front window trim the pinto is far from completed so far all  the suspension is done purchased a pst kit with all the ball joints and bushings. Landrum leaf springs in the back with konis, 2.3 wagon springs  up front cut some coils    and some mini stock shocks . Dick will a latter model sway bar from a wagon work on my 71 sedan next is installing a mild cage any tips my car came with a 8 point jegs needs to be welded in the whole bottom of the car has been striped and painted with por 15.
What window trim are you talking about Tachi? At what stage of completion are you at? Were you able to find a front spoiler from that guy I told you about in Washington DC? Just got me a duel Weber DCOE set up for mine. Nothing looks more like a boy racer than two Webers under the hood. Let me here from you and post some pictures.
L.D
Any tips removing lower window trim on a 71  sedan.
