v8 springs
Date: 05/07/2017 04:46 pm
Date: 06/07/2021 08:14 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 10/05/2017 02:26 pm
Date: 03/30/2021 12:29 pm
Date: 11/11/2019 03:38 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 08/17/2022 06:27 pm
  • Online today: 515
  • Guests: 269
  • Total: 269
need help identifying carburetor
Started by AndrewG, April 19, 2015, 09:46:20 AM
http://www.ihpartsamerica.com/forums/carb-tech/3153-weber-carb-rebuild.html
Go to the post #5 pic and the secondary idle speed screw is plainly visible right under the 'Y' in the word 'university'.................the small slot screw is staked but you adjust it if needed to make up for wear or just to get that secondary throttle plate in the correct position on its' slot or first hole. Some have a slot there, some a series of small holes, same thing, works the same way, like an accelerator pump for just off idle, they add rich as the throttle opens up away from idle otherwise the engine would balk at the sudden drop in vacuum (goes lean) when the throttle opens.
Thank ToniJ1960 for that link.........................
AndrewG
Quote from: amc49 on April 22, 2015, 12:47:51 PM
Any 5200, leave the idle limiter caps off. Pay attention to the choke plate qualifying setting, both on the choke cap and the drill bit size used to set the choke plate if not fully closed. Screw the mixture screw in to a light dead stop and counting the turns while doing so and start there when cranking car back up again, or 1 to 1 1/2 turns if lost. Start idle speed screw with the throttle plates both barely exposing the transfer slots or hole maybe .020" and that means setting the back barrel too. Many leave that back closed and it warps you into opening the front too much to then be too high in slots and then too rich and car won't pull right off idle.
Thanks for the great advice!
AndrewG
Quote from: amc49 on April 20, 2015, 07:43:49 PM
X2, the tag is what they will want to get a carb kit, the carb itself is a 5200 but the calibration on the tag tells what mods are on the carb, maybe 100 different ones.
Thanks.
I'm also looking for info on how to properly adjust the carb.
Can I use the adjustment settings for any 5200, or does the info on the tag on it's mods to the carb affect the adjustment settings?
AndrewG
I found the tag for the carburetor. It has the following info on it:
EOEE        RA
A        9K   9
Anyone have any info?
Thanks
AndrewG
I need to identify the carb on my 1980 Pinto engine.  The base of the carb is stamped with the number 8355.
The left side of the carb, on the assembly near the choke index notch, has the following info.
Motorcraft
47R-635A
9J24
Can someone help me identify this carb. I would like to be able to work on it and get the correct rebuild kit for it.
Thanks
