Date: 05/13/2021 05:33 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 10/03/2018 10:46 pm
Date: 02/05/2020 11:06 am
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 01/28/2021 03:49 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Interior Parts
Date: 08/07/2017 03:59 pm
  • Online today: 382
  • Guests: 368
  • Total: 368
Panel gaps
Started by 76hotrodpinto, March 24, 2015, 10:27:57 AM
X2.......................was looking at my Tempo last night and thinking of this thread. It has like 1/2" at door tops but because they are all even and door curves in at top to slightly mask it, it looks acceptable.
76hotrodpinto
As long as I have the factory gap set for a couple of the key spots, I find there's no reason I can't get everything to sit perfect. It's just metal. Unibody, 2-door... doesn't get easier.
Center the part in the opening there. The gaps are evened out at front, back and top/bottom of doors and same with hood although hood gaps can be bigger and still look good. Since hood overlaps grille to hide things or fudge them up to the eye then hood can go further back to look better there. I accept anything from 3/16" to up to 3/8" depending on where it is. Eye pleasing is good, or say both sides of hood the same or both doors the same. A lot of room for moving things around in there. The front fenders can moved backwards to tighten up any hole in door openings and the hood can be dropped lower to do the same. OEM measurement really means very little there.
The airspaces can move around after cars get jacked up in the air over and over, the unibody moves around some. Even simply driving the cars can move the unibody around, it is not rock solid and settles during use to be different from the day sold. Very common for hoods to say drift sideways to show the need for recentering after time.
76hotrodpinto
dennisofaz
Hi 76,
I measure 0.25" door to B pillar, and 7/32" center of hood to cowel.
Dennis
76hotrodpinto
I'm looking for the factory gap measurements for the rear of door to b pillar, and the cowl to hood. Please and thanks.
