1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 02/05/2017 09:45 am
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 04/28/2018 04:12 pm
Date: 04/14/2023 06:15 am
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 02/04/2018 08:26 am
Date: 06/12/2018 08:18 pm
Date: 09/06/2020 01:57 am
  • Online today: 176
  • Guests: 157
  • Total: 157
Cam knocking
Started by wx7pinto, July 22, 2005, 12:01:36 PM
dirt track demon
 ;D, that steering coupler was fun wasn't it?  I don't know about you but I said a lot of bad words when I changed mine.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
wx7pinto
Thanks for the suggestions,
I will probably do both the roller cam and the high pressure pump just to make sure. I want this to last until I retire, then major customization. Just keeping it running right now. Just had to replace the steering rubber coupling disk. took a Sat afternoon to figure out how to get that apart and back together.
Michigan Pinto
The oil comes up to the head and is distributed to the rockers and bearings though the cam shaft. The spinning cam shaft acts as a centrifuge and deposits the heavy metals in the oil to the I.D. of the cam and also around the little holes this will restrict flow.
dirt track demon
Good call Tony,  you could also replace the oil pump with a high pressure/ high volume unit.  This was something I did with every 4 banger i messed with, Ive never had any problems with my top ends, I always sent the bottom end thru the side of the block ;)
The PINTO!!
Install a roller cam from a Ford Ranger truck.
wx7pinto
I thought this would have come up before since I had heard oil pressure to the cam is a common problem. I bought my 79 wagon with 66K miles 17 years ago and have only put 20K on since then. It had a terrible knocking sound coming from the cam when it warmed up that would come and go so the first thing I did was check the cam. It had bad wear on the back lobe so I had the head rebuilt and replaced the cam and followers thinking this would help with the oil distribution. It lasted a few years but it came back. If I idle real slow the knocking will stop for a while. I installed gauges as part of my gradual 17 year customization project including oil pressure and I have good pressure all the time.  I haven't taken the valve cover off but I'm sure the same thing happened again. What can I do or is this just a "bad" engine with no hope?
Michigan pinto (the only one I have seen in years around here)
