Date: 03/07/2017 07:03 pm
Date: 02/28/2024 02:07 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Crane Cam
Date: 02/26/2018 07:50 am
Pinto for sale
Date: 04/19/2017 10:15 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 04/20/2017 10:10 am
Bumpers
Date: 07/06/2018 04:47 pm
Date: 05/24/2020 08:19 am
  • Online today: 642
  • Guests: 179
  • Total: 179
Anyone have roll bar pics
Started by Tonycando, February 09, 2015, 09:08:20 AM
entropy
Quote from: Tonycando on February 21, 2015, 12:24:43 PM
The build zone. Lol
Also gotta ask, what rim and tire combo are you running and what rim offset
Thanks again
I'm running an old set of 4 lug 15" Centerline AutoDrags  15 x 7 all around and with an additional pair of 15 x 4 pizza cutters for the front when I'm out doing serious social work.  Rears are 235 60 series Mickey Thompson ET Street drag radials.  Fronts are some no-name 235 50 series.  The pizza cutters are some BF Goodrich 165s.  I don't remember offhand what the offset is, but I've got it somewhere in my notes and I'll try to find it....or just go out and measure.  One more thing that needs to be said is that I *really* want to get different rims.  Some of my Centerlines...particularly the ones in the back...are leaking between the rim halves.  I've managed to improve 3 of the 4 7" rims by taking a wire wheel to the inside of the rim where the old and failed sealer was and replacing it with Permatex "The Right Stuff" gasket sealer.  If anybody's got a pair of 8" wide 15" 4 lug rims they want to sell....let me know.
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Tonycando
The build zone. Lol
Thanks again
JoeBob
I can't remember where I was reading. The Article said that back in the 70's people would rent a pinto from Hertz and then install some kind of temporary roll bar.  They would have a cheep weekend racer. Does anyone know about that?
77 yellow Bobcat hatchback
Deuteronomy 7:9
Tonycando
The trunk is in now and welded up solid, as you have done with a tube running from wheel well to wheel well I plan to run a 2x3 welded down solid to offer support to the upper shock mounts and from there run more 2x3's down to connect onto the subframe connectors essentially making a frame from front to back all supported with the cage to be built yet.
I got lucky , through a buddy of mine I have set it up for a retired gent that used to build cages in the past  he will come down to my garage with his bender and bend up my cage on site for me to weld in. Lots of pics to follow on that for all to see as well.
Tonycando
I welded a 1x2 between the upper shock mounts and have now welded a 2x2 from the rear shackle mount and upper shock mount.
Tonycando
Entropy. Wow nice pics thanks a bunch,looks like a well done build and offers all some insight on what can be done.basically you went with a skeliton system and it looks like it will work dam good.
Lots similar that I am doing on mine except I am grafting lots into the floor and existing components of my pinto.
Thanks for sharing
Tony
entropy
Ok...finally had a chance to take some shots of it.
overview through the hatch
Passenger side rear:
Moving forward...
Higher in the same area
Main hoop, etc.
Can't really call 'em door bars...
Up front
You can kinda' see the halo bar....passenger side
Lurking in dark parking lots, looking for trouble...
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: Tonycando on February 15, 2015, 01:19:05 PM
Absolute would be helpfull,if not for me than the next guy that does a search also,
Ok.  I'll shoot some tomorrow.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Tonycando
Tonycando
Quote from: entropy on February 14, 2015, 06:56:03 PM
I've got a 10 point in mine, but it's not a trunk car...would that still be helpful?
Go to  http://www.izzyscustomcages.com for the best roll cages. He does mail order kits too.
entropy
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
76hotrodpinto
Tonycando
Now that's descriptive,thanks that left nothing out visually except the skirt and muffin. Lol
OhSix9
I put an 8 point in my wagon. In edmonton so also a stuck canuck when it comes to easy access to parts.  Anyways, they do have a prefab kit. competition engineering makes it.  think it was 300 bucks from mopac including the main hoop. I made internal subframe connectors and tied everything together at the main hoop.  i put a swing out door bar on the drivers side with 2 sets of m/f clevises and let the skirts climb over the bar on the passenger side for fun. With heavily bolstered race seats id recommend a quick release for the steering wheel too.  there is no ingress or egress without one the other or both depending on your frame.    had to flip the arm rests side to side and chop off the pull handles to clear the bars.gonna find some late model stuff that didn't have pulls to substitute eventually...    Had to make some minor concessions to the front placement being that it's tight like a nuns muffin for a 6ft4 pilot myself and squeezing the door bars past the seats left few options. but I ran add'l plates on the outside of the front  mount point and added another plate in front of the door tied to the rockers with another support going up to the door bars.
Virgil to Sid
Tonycando
Yup expensive to be a Canuk. Yes lots on a Google search for purchase of a kit but I really wanted to see how people have done theirs and differences between how and why they did it the way they did
My last build a 64 Fairlane I had a 6 point installed and if I ever.built another one knew what changes would happen. Myself being 6'4" and 285lbs warrants fit issues and this time I want to do it right. Thanks
Tony
He's in Canada. That usually kills cheap/free shipping.
But yeah, do a search using ford pinto roll cage if you haven't already.
Just type in ford pinto roll cage. There is a company on there that makes pre fab roll cage kits with free shipping.
Tonycando
Well my 40th search under roll cage show a few results but I have to say not a lot out there,I'll make sure and post lots of pics when I get on mine,just not sure yet from whom to purchase. S&W wants 975.00 for a 12 point which works out to about 580.00 for shipping to my door which to me anyways is out of the ballpark. Waiting on a price from  Autoweld and am hoping for a better price.
I did get a local price for a custom supplied and installed 12 of for ballpark 1800 which is I think real fair. But he is booked for at least 3 months
Maybe it's time to buy the tube bender I ve always wanted
Sending a good contact in Calgary via PM....
Tonycando
I'm just about at that point and am looking for ideas,I can not seem to find any pics of placement of the rear bars in the trunk and am wondering how far forward some have run those bars,I plan on doing a custom 12 point with swing outs.
Tony
