Date: 08/09/2018 11:09 am
Radiator
Date: 05/27/2018 06:07 am
Date: 10/03/2018 02:00 pm
front end parts
Date: 03/30/2018 12:48 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 03/16/2017 10:00 pm
Date: 06/07/2021 08:14 pm
Date: 04/20/2017 08:56 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 548
  • Guests: 481
  • Total: 481
New non-pinto guy has questions on 71-73 front brakes.
Started by produster, July 22, 2005, 07:00:03 AM
produster
If I raised the upper control arm 1" would it then fix that?  Also replace the lower control arm with a tubular unit.  Will the lower ball joint from a MustangII fit the early Pinto?
I am not worried about making the changes to the car.  I got the car with this front ends on it and it has been nothing but trouble.  I feel as though I am chasing my tail.
Thanks for the help.
The mustang II spindle is 1"+ taller.
It would throw off the geometry of the suspension.
Contact wilwood brakes they make kits for the early Pinto also there is a person on ebay that is selling front brake kits.
produster
Yes it is a rack.  It steers from the front.
Can I change over to a MustangII spindle using the current upper and lower control arms?
OK YES you have the 71-73 Pinto front.
Are you using a rack and pinnion?
Does your duster steer from the front or rear of the spindel?
produster
yes they do.  The caliper bracket has a slide with a couple of cotter pins too.
Hey Produster,
Do the calipers on your duster have what looks like GIANT wire bobypins?
Just tring to establish what you have befor I try to help.
produster
Hello all,
I am in need of some help.  I have a tube chassis Duster and was told it had a MustangII front end in it when I bought it.  Having never been invlolved in MustangIIs or Pintos for that matter, I took it as what it was.  Well come to find out I have a 71-73 Pinto front end on the car.  I found this out because the front brake calipers were seized, not fun trying to stop!!!  My first question is, did they make bigger front disc brakes that are a direct bolt on.  Second, do MustangII spindles use the same ball joints as the 71-73 Pinto spindles?  If not do either the upper or lower interchange?
I ask this because the upper control arm is a tubular one and the lower looks to be O.E.M. stamped steel.  And if I have to replace parts I would like to know what I need to replace  with out changing parts that do not need to be replaced.  The tubular upper control arm looks to be of aftermarket and not a home made one.
