72 Pinto
Date: 03/07/2019 12:07 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 02/22/2017 01:58 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 12/31/2017 09:03 pm
Date: 08/17/2022 06:27 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 08/02/2019 04:18 pm
Date: 04/24/2018 11:45 am
  • Online today: 2,773
  • Guests: 1448
  • Total: 1448
Taking the turbo plunge!
Started by 76hotrodpinto, January 27, 2015, 11:59:24 PM
76hotrodpinto
I'm about to scrap the rest of the tbird. I have everything I want off of it. Is there anything any of you want off of it before I do? No charge, just cover the shipping.
76hotrodpinto
Ordered the bellhousing and fork from a reputable parts hoarder! Thanks PintoCrazed. I dug out my ol' 100 amp mig to get ready for the sheet metal work on the pinto. I think I can get most of my welding done while keeping the pinto drivable, cutting the down time for it by a couple of days.
Is the electric speedo something I need for the engine management system? I want to use my mechanical gauge.
Pintocrazed
JUST LET ME KNOW.IM NOT DOING ANYTHING WITH IT
76hotrodpinto
Quote from: Pintocrazed on May 11, 2015, 12:03:44 PM
I GOT A BELLHOUSING FROM A 93 MUSTANG 2.3 THAT WAS CABLE OPERATED
If I can't find one local in the next day or two, I'll be hitting you up.
Pintocrazed
I'm sure the bellhousing etc. are out there but it may take some hunting.  While I limit myself to "self serve" yards finding anything Turbo Coupe of late has been extremely difficult.  I did my swap in mid-2008 and at that time the two yards I frequent probably had 3-5 T/C's every month I would visit. Within six months of starting the project it dropped to 1-2 T/C's per visit.
In the last two years I believe I have found 1 T/C. that car was an '88. Great for the LA-3 ECU, but it would have the hydraulic clutch which the Pinto swaps don't need.  These yards aren't out in the middle of nowhere either.  They serve the western side of Los Angeles, the second largest city in the country.
So, again, another reason to be thankful for having the donor car.
76hotrodpinto
Well I didn't pull the steering column looms, so it should be less than yours. I pulled out some extras along with what I need, just to simplify removal. I'll trim that out during install. I got to have me some fun "disassembling" the inner dash/instrument supports... with a hammer! Having a little trouble finding the right bell housing/fork setups. Anyone got an extra one they want to part with?
Ahhh..., yes, fond memories. Why is it when it is someone else's wires they seem so few? LOL And, yes, I did cut the cradle support to get the engine out. A salvage title and a rat in the HVAC system saw to that.
Nice find under the shifter boot!
76hotrodpinto
The juicy circuit laden fruit, fresh picked!
Something is missing...
Oh, there it is.
And the little gem I found under the boot.
There ought to be two dipstick holes in the block on the driver's side. I did almost exactly what Wittsend did as far as placement. The original dipstick hole rearward of the oil cooler will have to be plugged and the front one will have a welch plug in that needs to be knocked-out.
I had hoped to reuse the plug, but it shot into the grass and leaves beside my workspace when I punched it out from the sump side.  :P
I also used a C-Line 7qt pan. The dipstick reads a quart+ low when there are seven in the sump.  :o
On a side note, I don't think the low oil sensor is tied to the ECU, so disconnecting it shouldn't pose a problem. Most of them leak anyway.
Since it was about seven years ago I've forgotten exactly what I did. But here are pictures of the installation. As you can see in the lower view image the stick goes inside the motor mount area, but towards the back. As best I recall this is the T/C stick and tube.  There might be a height difference between the front and back holes.  With the pans off I would measure where it is at presently  and then again after it is moved to ensure that "full" is really full. The upper view image shows how I tucked it close to the intake just to get it out of the way. I'd assume if you just used the Pinto stick and tube in the forward hole everything would be fine.
Quote from: 76hotrodpinto on May 08, 2015, 12:27:50 PM
On the dip stick subject, you didn't move to the deep end of the pinto pan?
Not to Hijack, but I've been in the Deep end of my Pan for some time, and I'm sure I've been called a Dipstick too! ;D
76hotrodpinto
76hotrodpinto
Quote from: Wittsend on May 08, 2015, 12:06:49 PM
Glad the removal tool worked.
The dip stick move is simple. I did a slight modification to "tuck in" the stick to the intake manifold (but at the moment I can't remember specifically what it was).
Yes, I just did without the oil level sensor (that is what you are referring to?). At least in a junkyard getting one of the two star bolts off off the oil pick up can be a real pain. The T/C oil pan gasket isn't cheap ($25-$30) but I reused it and don't have issues.
Man, this is really having me relive my project. You forget all the stuff you needed to acquire even having the donor car - oil pan, oil pick up, engine mounts, bellcrank bellhousing, clutch pedal, clutch cable, external fuel pump, radiator,  electric cooling fan, smaller heater motor. Then there are the modifications to the PS inner fender, trans tunnel, trans mount, VAM mount, heater motor, radiator cradle, motor mounts, steering rack (clearance), top of intake/throttle body (clearance) windshield washer tank, fuel and return lines - routing the wiring and mounting everything etc. And then I made it more complicated with with the T/C steering column and fuse box! It's time for a nap just thinking about it all.
At least you have a 76 which makes the motor mounts simple. I had my engine in/out seven times before committing to welding the mount. I recall 65SC said he did about the same.
It's all worth it though. And fun for the whole family. Hopefully you don't go full senile on me, I'm sure I'll be asking for many more wisdom nuggets as I progress. And Thanks to you guys for all the help. This would be much less enjoyable if I was going in blind.
76hotrodpinto
Got a tool like the one in the video. Worked great! So how are you guys addressing the dipstick issue? I'm assuming you moved it too, when you put the pinto oil pan on. And did you drill a bung for the oil sensor in the pinto oil pan, or delete the sensor?
I always left the line at the rail alone and just disconnect further down at the solid fuel line. The plastic clip comes out the side and then it either pulls off, or possibly a small screwdriver helps to remove a "snap" type of retainer.  I have a vague recollection that the supply/return line connectors are different and each requires one of the methods???
The tool you want (assuming you elect to remove the circular spring clip at the rail) is used for auto air conditioning. They come either as a plastic, stand alone size, or as a two sized piece die cast part that has a center pivot like pliers.  The few times I've used them I had trouble. I eventually cut a short piece of PVC pipe in half, slide the halves into the area and pivoted  the pieces off the raised edge of the hose connector.  This forced the spring outward and allowed the removal. If your hose doesn't have a raised area tape or thick wire would probably work.  You just want the plastic halves to pivot so they will force the circular spring outward. Large pliers or a hose clamp will work if finger pressure isn't enough. I had to alter (thin) the halves diameter somewhat to fit.  Just be forewarned that even with a manufactured tool it can be frustrating if it isn't the exact right size.
76hotrodpinto
Is there a part number for that tool? Or at least a name for it?
76hotrodpinto
Quote from: 65ShelbyClone on May 07, 2015, 12:21:19 AM
The clips are just a redundant safety feature; there is a garter spring inside the [spring-lock] connector that you have to release with a special tool in order separate them.
I found this video in a Google search:
https://www.youtube.com/watch?v=xf8D0dOtv0k
Mine has Bundy fittings with plastic (one-time use) safety clips since it's pre-'87. I like the spring-locks better though.
Ahhh. I see. Thank you sir.
The orange one on the turbo is the oxygen sensor ground, so yeah, orange must have been grounds.
There is an orange ground wire at the turbo and another gray ground I believe near the coil.  This is all from memory and I'm sleepy so accept this advice with caution.
Oh, yes, and periodically mutter a "Thank You" that you have a donor car to pull all this stuff from.  :-)
76hotrodpinto
Getting there. What's the deal with the fuel line connectors at the fuel rail? How do they disconnect. I removed the clip, bit I didn't get any further than that with them.
Quote from: Wittsend on May 06, 2015, 10:40:51 AM
The biggest problem I had was when a wire color was used for multiple purposes. It would branch off in multiple directions and I'd have to chase it 4 or 5 different places. A wire to the VAM may go through the TPS and other places (as an example, not exact) before it gets to the ECU.  There is a resistor wire in the steering column. It says specifically on it "do not cut" but you have to to get it out. I never changed its length, but I did solder it. No other turbo swap person has ever mentioned it so maybe it is less critical than implied.
That was a PITA with mine too. Grounds went every which way and weren't always the same color (to be fair, most were yellow...or was it orange?) and some +12v wires branched every which way. Many were covered with melted tape adhesive. I remember the coil wires being daisy-chained to a bunch of other junk like HVAC or emissions sensors.
QuoteThere are also diodes imbedded in the harness. I can't recall if they have any function for engine management.
Yes they do. There's one for the idle valve that is reverse-biased so it protects the ECU driver from inductive kick when the valve is switched off. All the other solenoids and relays that are controlled by transistors have a flyback diode somewhere for that purpose.
I liked the T/C seats a lot too. And thus, installed them in my Pinto. They do seem different though.  I'm 6' tall and long waisted (sitting I'm about as tall as someone 6'4").  I found that the power seat mechanism created too much of a problem height wise and mounted them to the Pinto rails. The seats are very tight side to side and it makes pulling out the difficult Pinto seat belt even harder.  Here is a link to what I did.
http://www.fordpinto.com/index.php?topic=11742.msg75729#msg75729
76hotrodpinto
Can I come use your patio? Aahahahaaa... I'm just stripping out the engine management systems. And maybe the power seat circuit, I may be putting those seats in too. Could be the most comfortable car seats I've ever rested my cheeks on!
When I dissected my '88 harness I laid it out on the patio and spread it out like it is located in the car. The biggest problem I had was when a wire color was used for multiple purposes. It would branch off in multiple directions and I'd have to chase it 4 or 5 different places. A wire to the VAM may go through the TPS and other places (as an example, not exact) before it gets to the ECU.  There is a resistor wire in the steering column. It says specifically on it "do not cut" but you have to to get it out. I never changed its length, but I did solder it. No other turbo swap person has ever mentioned it so maybe it is less critical than implied.  There are also diodes imbedded in the harness. I can't recall if they have any function for engine management.
As I said before I used the T/C steering column, fuse box, relay box, wiper box and cruise control box. So, that added significantly to the problem.  My T/C also had ride control and ABS and those computers took a connector similar to the ECU (meaning many, many wires). Be careful about the grounds. They are soldered mid harness and branch all over the place.  I'm pretty sure the only thing going towards the back of the car is the fuel pump wiring (Primarily a Pink/black wire I recall). I highly recommend you keep the shut off switch.
All the best. If you are doing just the engine management, while not easy, it should be far simpler than the route I took.
76hotrodpinto
After pulling out the power steering pump and associated bracketry, I remembered that I don't want another hydraulic system on the pinto, so I'm hunting for the bellhousing and fork to run a cable.
76hotrodpinto
Stripped the motor down to the block and head on the exhaust side. It came apart more gracefully than the other motors. Pretty clean for a driver too. Been tagging every plug as I go, and some hoses. Will strip down the other side tomorrow and tag more wires. Can't wait to start the loom separations... not. I have some nice diagrams though, and it is a mostly isolated system, just bundled with SO MUCH other stuff.
Quote from: Wittsend on May 05, 2015, 02:45:21 PM
So, it seems one should be careful what bleed orifice they use if they are mix/matching parts because a little, tiny hole can sure make a difference. Which, BTW I assume the boost can be altered simply using (making) a smaller orifice? This seems rather simple and cheap over the more expensive boost controls.
It is cheap and it does work, but I hear that small changes to the bleed diameter result in large changes to boost. A smaller orifice will decrease the maximum boost, BTW.
QuoteThe speed control and the engine RPM likely do make sense, but it must have a wide, delayed range given the action of gear changes and tire slippage.
I think the powertrain engineers figured that there wouldn't be any wheelspin with a 3400lb+ chassis and that if there was, ramping up the boost would only make it worse. It's my understanding that boost was limited below 4000rpm in order to preserve the transmissions.
QuoteFor those of us who forgo the speed sensor for the manual speedometer, do you think there is any adverse effect to the ignition/fuel/boost the ECU is allowing?  There are some Tee speedometer drives out there (I have one for a Halda Twinmaster) if I need to reestablish it.
The ECU probably falls back to some default behavior if it detects a VSS failure, but I don't know what that behavior is.
QuoteLastly, what is your take on the **** referring only to the overboost alarm. http://beta.askatech.com/askatechlive/aatfileshare/references/fasttrack/f023.pdf If you look at the larger table (83-86) the notation at the bottom definately is stating such saying "pressure warning." It is my inclination to see it as such for both (also given the column it appears in) and not an indicator of actual boost levels under and above certain RPM's.
It seems to indicate what the nominal boost levels are under which conditions although it is not at all clear. The overboost buzzer is typically tripped by a pressure switch, not the ECU, which would explain why I've never heard of one that triggered below ~17-18psi.
