Date: 04/21/2017 02:03 pm
Date: 02/14/2018 01:34 am
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 06/28/2019 09:14 pm
Date: 06/07/2018 01:45 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 08/22/2018 09:23 am
Date: 11/23/2017 05:44 pm
Date: 10/05/2017 02:26 pm
  • Online today: 452
  • Guests: 239
  • Total: 239
rear main seal in my swaped motor
Started by madscientist, July 21, 2005, 04:49:54 PM
Some suckers are always trying to ice skate up hill.
madscientist
how do i pull the motor and transmission out of the car the easiest way
madscientist
what can i do to make sure it doent leak
Bwayrshires
You will have to pull the pan off and remove the rear main cap, you may also have to loosen the other main caps so you can work the new seal around the crank. Make sure to check the crank for any grooves, I have seen people install new seals only to have them leak again soon afterwards.
Brian
madscientist
completely remove or just pull it down
billnall
NO NOT EASY!
69 5.0 had a 2 piece seal so you will have to remove the oil pan.
Ford Parts Man
madscientist
i have a 79 pinto with a 69 5.0l with a c5 tranny. didnt do the swap so my rear main is leaking is there an easy way to do it?
