Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 01/19/2020 09:06 am
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 09/03/2018 08:58 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 06/24/2020 06:12 am
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 11/11/2019 04:49 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
  • Online today: 1,137
  • Guests: 787
  • Total: 787
8" rear end question.
Started by 76hotrodpinto, December 27, 2014, 09:42:50 AM
jonz2pinto
Some one recently had the same issue .It ended up being  the u-joints. I hope it is something that simple.
Pinto-is short for pint-o-fun.
76hotrodpinto
Yeah, I was trying to get the car back to basically stock appearance. But the 5 lug seems to have the potential for larger brake discs, via larger wheel options. I like that, maybe more than having the stock 4 lug look.
I'm going with 5 lugs all the way around. Its so much better. A little costly, but it opens the door for a lot more wheel and brake options...plenty of parts for an 8" BTW. Not as many as there are for a 9", but still plenty.
76hotrodpinto
Quote from: amc49 on December 30, 2014, 02:38:54 AM
Are you sure the clicking is in the center? Could be a brake issue. As Dick says, if grease with no graphite in it used on a p-trac type rear it will snap and make noises but generally when turning corners and not straight ahead.
Not certain yet. It only does it on coast when slowing, so it seems like sloppy rear end at the moment. Doing the brake swap either way though. Them old drums get pretty warm on track days.
There is or was one out there, I thought i had it bookmarked but I can't find it.
It was in the $400-500 range.
If I can find it again I will post it here.
76hotrodpinto
So far the only disc brake option I've found is 5 lug. Anyone know of one that lets me keep the 4 lug setup?
If the rear end has a posi and the wrong grease, it will make all kinds of odd sounds. Look under 8" ford rear ends on e-bay. Lots of parts out there.
Pintocrazed
There's many many places that carry replacement parts an performance parts for the 8 inch rearend.but that's the only knowledge I have for them
76hotrodpinto
I just took the pinto for a 800 mile trip around the northwest, throwing pretty boxes at distant relatives, and getting the hell out of there before the egg nog runs dry, and everyone realizes we don't hang out for a reason.
Anyhoo, I started to hear a little clicking coming from the rear end, the cars not mine. I have some experience with the 9" fords, but this will be my first 8". Is it basically the same design, just a smaller? Or completely different? Any advice before I tear into it? Are new parts still available? And while on this subject, are there any disc brake conversions for the 8" ford? I'm pretty sure it's from a 78 m2.
