Pinto Watch
Date: 06/22/2019 07:16 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 06/19/2018 03:58 pm
Date: 07/08/2017 08:53 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 04/25/2017 12:17 pm
Date: 01/24/2021 07:54 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
  • Online today: 515
  • Guests: 296
  • Total: 296
Glue
Started by 1973FordPinto, December 24, 2014, 02:05:36 PM
1973FordPinto
Well, thanks for the detailed explanation.  It's harder than I thought.  I'll keep in mind what you said.  I don't plan on taking the car out in bad weather.  Otherwise it will sit in the garage, which is hot in the summer though and cold in winter, which makes everything contract and expand, which wouldn't help any.  Got another grille and it came with a crack in the middle.  Hopefully we'll be able to make extra mounts on the grille to stabilize it.
Great ideas!
Luck with that..............heat warps and biodegrades the plastic and cannot get away from that. Usually not enough mounting points and I generally remount with additional mounts if it begins to crack. That pretty much stops it. Glue really unless a non-stressed part of grille will not work, it'll simply crack again just past the glue joint. Vibration figures in there a bunch. It adds up at the mounting points and in the long unsupported spots. If the plastic has biodegraded enough so you can cut off crumblies with a fingernail give up, the plastic is dead. Don't waste your time gluing up like a screw boss, putting the screw in will simply crack it again.
Mine cracked and a new previously non-existent mount put right there stopped it for years. You have to make sure it fits perfect, warp any and it simply breaks again. I spent like ten minutes shimming it just right to be a slip fit.
Epoxy, and not the quick dry ones, they are much weaker..............the 24 hr. stuff. If actual joint will be hidden then put metal of some type across the joint to bring the strength up 10X what the glue by itself will hold. Glue by itself is weak, but layer it thinly and other substance in there to add strength.......................well,............................they make airplane wings out of that.
Luck......................and Merry Christmas
1973FordPinto
What is the best brand/kind of glue to glue a grille back together?  Something that is sturdy and can take the heat,  vibration and banging of a car being driven.  Don't want it cracking again if possible.
Thanks.
