Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 08/08/2017 01:44 pm
Date: 03/06/2019 06:40 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 02/22/2017 01:58 pm
pro stock front end
Date: 06/28/2019 07:43 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
  • Online today: 506
  • Guests: 252
  • Total: 252
Ethanol and rubber parts
Started by AndrewG, November 15, 2014, 11:56:14 PM
Aside from the corrosive nature of Blended Gas/Ethanol on metal pieces, There is a real danger of using ethanol fuel even at 10%  to gasoline ratio.  The original fuel hoses ( rubber) were never designed for any ethanol exposure .  Those Hoses were a Nitrile rubber compound and subsequent exposure to any ethanol or even that Bastard brew with MTBE  caused fuel leaks everywhere that a clamp was used.  In summation your rubber components must be made of a Fluoroelastomer based rubber blend to fight off the degradation  and rot of hoses and gaskets.  On the Hose front , if you want to stay ahead of the EPA and the CARB Nazis , buy  Gates "Barricade" hose for fuel leakage or Permeation ( New vapor  leakage laws)  and buy the Correct hose for either EFI  or Carbureted use.  Fuel filler neck issues can crop up too.  Look for the SAE J30R9 marking as the minimum standard, and SAE J30R14T1 for the latest permeation for vapors.  Do not ignore this, as a vapor leak can set the car on fire in an enclosed space with  mortal results for property and life.  When the EPA goes to 15 % Ethanol , this whole circus will begin again with older cars.
Carbon footprint , your latest boondoggle and the means to get you on the train or E car for transit
Pintosopher, Fuelish Warrior and Bartender for the masses of  "Drivers"
No problems in any of my vehicles but I don't let them go dry either.
AndrewG
OK, thanks for all those gas price updates...... :o
Getting back to the original point of this post,  anyone have any problems with fuel pumps and carbs as a result of using gas with ethanol.  I don't have access to ethanol free gas here, so I'm wondering if I should be updating my carb and fuel pump to avoid problems.
Quote from: 76hotrodpinto on November 17, 2014, 10:27:16 PM
Now they're pushing a shadey-butt street repair tax too.
You know somebody is lining their pockets, greedy basturds..
76hotrodpinto
Quote from: 74 PintoWagon on November 17, 2014, 10:23:58 PM
Dam gubment rip off.. >:( >:( >:( >:( >:(
Quote from: 76hotrodpinto on November 17, 2014, 10:22:05 PM
Regular pump gas is about $3.25 all around town. Super is about .25 more. And that's waaay down.
And that's still high, here it's $2.99 but in Phoenix it's down to $2.65..
Quote from: 76hotrodpinto on November 17, 2014, 10:15:49 PM
We have horrible fuel taxes here. No sales tax, so they get it where they can.
76hotrodpinto
Wow!  That is some price!  I run ethanol-free regular in both my Pinto and my Rolls-Royce.  It is currently selling for $2.99 per gallon here.  Filled up the truck with regular gas from Sheetz in Fishersville VA today (10% ethanol) which was $2.49.
Dwayne :)
76hotrodpinto
Quote from: 74 PintoWagon on November 17, 2014, 10:11:04 PM
WOW $6.00 a gal that sucks, you can buy Avgas cheaper,lol..
76hotrodpinto
I'm pretty lucky here. I have access to 3 stations, on my side of town, selling ethanol free gas. One has high test, but damn, it's close to $6 a gallon right now. Been running half and half for daily driving, and just high test on track days. It's even more expensive at pir. I was just shocked that it was still fairly easy to get in this prius driving hippyfest I live in.
Yep, did the same when we ran the Altered started a lot quicker.  We have one station here that has ethanol free gas but it's 91 and they get $4.16 a gal, bummer...  :( :(
Ethanol laced fuel is somewhat harder to light off when stone cold motor. Why we always lit the pro stocker off with gas squirted into intake when running alcohol in it.
Sh!t, leave a car sit for 2 days and the thing don't want to start with dam skunk p*ss... ::) >:(
Much, much worse if the car sits with no driving for long periods. If used day to day it is pretty much transparent until a long passage of time. The damage to pot metal like what carbs are made of easily as bad as to rubber. When car sits the ethanol then phase separates from the gasoline portion by drawing water and the water is what is necessary to produce the byproduct acids that cause much of the trouble. Drive car commonly to keep fuel fresh and much less trouble. These are early cars with vented systems and not sealed nearly so well as today's computer cars which can sit for longer periods without the fuel separating.
You can clean parts with ethanol laced fuel outside on a humid day and draw water into the mix in less than 5 minutes, the fuel then turns cloudy, the mark of separated fuel.
AndrewG
From what I have read and heard, the rubber just needs to be in contact with ethanol to be damaged and potentially cause a fire.
Here is one video discussing this issue:
https://www.youtube.com/watch?v=Kud3AZFcP6w&feature=youtube_gdata_player
Haven't had any problems so far with that skunk pi$$, I don't think there's a problem unless the system is drained then the rubber dries up and gets brittle..
AndrewG
I've been reading about the problems caused by the addition of ethanol in modern gasoline.  Seems that it is recommended to replace rubber parts that come in contact with gas, such as fuel pump diaphragms and carburetor parts, as the ethanol will destroy them and cause a fire hazard.
Does anyone have recommendations regarding this and which parts to be replaced on the 1980 pinto 2.3 L.
Thanks
AJ
