V8 rear end
Date: 04/12/2018 10:57 am
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Date: 08/03/2017 07:40 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 07/11/2023 11:39 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 177
  • Total: 177
Aluminum flywheel?
Started by sponge003, November 07, 2014, 05:44:32 PM
sponge003
Awesome thanks!!!!!!! AGAIN!!!
Merry Christmas also really appreciate the help
I use a late 80's Ranger starter with one of those flywheels. The starter is just like a hi torque mini starter at 1/4 the price. It'll turn over a 2.3L like there's no spark plugs in the motor. Try it / you'll like it.
sponge003
The speedway flywheel is 135 teeth on the ring gear versus stock 132.
Will this cause any issues with a starter for a 132 teeth flywheel?
Appreciate all the help!!
Quote from: dick1172762 on November 10, 2014, 09:18:20 AM
You will need the throw out bearing listed with it as the flywheel is thinner and requires a longer bearing.  When you get the bearing, take it to a really good parts man and find out what it really is made for, so you can buy one if necessary some day cheaper.
Go to page 359 / top left corner / 2.3 release bearings / 605-498F and if you haven't done so, go to http://www.4m.net/archive/index.php/f-24.html to read all about it.
X2 for sure if that's been done. Best way to crunch a trans there is.  10X as fast if motor mounts are rubber and solid trans mount. You just can't do it.
Quote from: sponge003 on November 12, 2014, 07:33:24 PM
OK I cant seem to locate the part # for the Throwout bearing
I am putting in a T5 also if that matters, the 4 speed is cracked very badly at the bellhousing.
Really apprecviatwe the help
Solid motor mounts will crack bellhousing and tranies. Never use them.
sponge003
sponge003
It is on page 359 of their new Race catalog, in the pony stock section. Part # 605-1535. It is listed as 9 1/2 lbs and is $249. The picture shows it to be for a stock clutch. If you have an old catalog, just look in the pony stock section. 99% in that section is for a 2300 engine. Good stuff.
sponge003
Quote from: dick1172762 on November 08, 2014, 11:35:40 AM
Best place is the 4m.com web site. They have a good classified column. Make sure the flywheel is drilled for the size clutch you have. They come in stock / 51/2" / 9" so make sure you get the right one. Speedway has a 9# steel  flywheel that is cheaper than the aluminum ones. My last aluminum one also was 9#.
4m classifieds are a little messed up as 4+ year old posts are showing back up
Do you have a part number or link to the 9# flywheel?
all I could find was an 11#
sponge003
Need to look at the 9 pound steel from speedway!!!
Thanks
sponge003
slightly modded 2.3 in a 79 pinto road racing lemons
going to a t5 and was looking at aluminum flywheel;s
any suggestions? anyone got a used one?
thanks
