1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 08/05/2018 01:58 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
postal pinto
Date: 06/03/2020 09:31 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 05/13/2021 05:29 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 08/01/2018 01:17 pm
  • Online today: 481
  • Guests: 148
  • Total: 148
v6 rebuild
Started by krazi, November 06, 2014, 09:13:22 PM
Did the same thing to my 76 pinto , removed the engine from my 79 cruzer wagon to overhaul , but changed things along the way ,only I had a comp cam , pn 36-204-4, ck the spec could be almost the same as the isky , then I used the 2.9 crank out of my wife old bronco II( cheep stroker)  , had to machine the nose of it so I could use the gear from the 2.8,  the rods are the same for both engines , the piston I used was for the merk scopero , small dish on top, 9 to 1 compression , you could use the stock 2.8 pistons for over 10 to 1 , also found the heads are not the same for certain years , the 76 had gaskets for the spark plugs , the 79 did not , (taper like the new cars and easyer to find, ) next drill a hole in each head using the hole in the  head gasket  to drill between the exhaust valves , this helps cool the hot spot there, just one hole per head, I made up a TBI injection for mine and used a A4LD trans for the over drive , hope this gives you some ideas on what you can do, later Blaine
krazi
I put one of my spare 2800's on the engine stand the other day, and i'm starting to dismantle it. when I re-assemble it, I want to use the isky cam I have. I was wondering if anyone has used one yet. also wondering if there would be a forged crank and pistons available for this engine. also wondering what common problems I should look for or expect when the block and heads come back from machining. I'm planning on a .030" over-bore, a high volume oil pump, and eventually an offy intake with a 4 bbl carburetor.
I've driven the stock 2.8 for 12 years with a heavy right foot and cant seem to blow it up. so I know this is a stout little engine. haven't even checked the rockers in it for adjustment. most reliable $50 car I've ever owned
yeah, I'm Krazi!
