74 hood
Date: 07/03/2017 03:46 pm
Date: 06/07/2018 01:45 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 09/22/2020 11:33 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 03/13/2021 12:57 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
  • Online today: 1,292
  • Guests: 675
  • Total: 675
78 valve cover gasket help
Started by ToniJ1960, October 27, 2014, 06:10:12 PM
slowride
I don't even bother with that cork gasket anymore. This costs a bit more, but never leaks...... VS50043R-1
Whatever you do, if the mating surfaces are not dead brand new spic-and-span clean and dry you will most likely be doing it again, many do.
ToniJ1960
Quote from: dick1172762 on October 28, 2014, 01:42:48 PM
NO-NO-NO  Never us oven cleaner  on an engine while its in the car!!!! The oven cleaner will remove any paint it comes in contact  with. Its good stuff if you can keep it off the painted parts. Best to go to the car wash and clean the  whole motor. Take a roll of toilet paper to dry out the dist after you do the wash. Works for me Tonij! Make sure you get the Felpro one piece gasket as they never leak and are so easy to install that you'll wonder how you got along with out it. Cost more but its the last one you'll ever have to buy. They are blue in color and are some type of soft plastic . Don't let them try to sell you a cork gasket.
I got felpro 50126
76hotrodpinto
I've used the orange based stuff a million times, won't hurt the paint. Not the bake in style stuff. That crap will fume up the cab for years to come.
76hotrodpinto
If you don't have a pressure washer, squirt some oven cleaner on it, avoiding directly spraying on non metallic surfaces. Let it soak for a while and hose her down, put a bag over the distributor and carb. If there's not enough slack on the heater hoses to clear the cover, remove it from the manifold, after draining coolant, or just get messy with it, your choice. After you get it up off the head, vacuum out all the crap that may still fall into the head. For gasket removal, I use razors, brass and stainless wire brushes and rubbing alcohol. I takes patience and technique. Do not scratch and gouge either gasket mating surface, but get it all off. If it ain't metal color, it's not clean. The alcohol is only to de-grease when you have all the surfaces clean. Do it right, or do it again.
ToniJ1960
  The block is crudded and gummed up along the seams of the calve cover. I doubt spraying will take it off. No space on the drivers side of coutrse to get hands in there to scrape it off.
Can I just remove the darn cover and clean it then, and wipe out whatever junk falls inside?
Also about this cooler line that goes over the top. Someone spliced in a flushing t, but I still think it will have to be disconnected or loosened at the intake or wherever it snakes its way back to on the drivers side.
Can someone advise me on this? What kind of scraper will I need, should I spray the old gasket before I scrape it etc.\
Also chiltons doesnt give a torque spec for the bolts :(
